Creative X-Fi "Music Creation" Mod
Creative X-Fi
Mainboard On A Tray
Creative X-Fi Creative X-Fi
Almost there. I just need to drill out the rivets joining the motherboard tray to the chassis rear panel. Hmm, I seem to amassing a fine collection of scrap metal. It may come in handy I guess!
Here you can see the chassis rear panel and disassembled motherboard tray. I removed the PCI backplate because I needed to cut down the motherboard tray first so it would fit in to its new case. The PCI backplate will be re-attached after this has been done, using rivets.
Before removing the PCI backplate I marked where it was on the motherboard tray so I could replace it in exactly the right position later. It was to be altered and I wanted to make sure all the PCI slots accurately lined up again.
A uATX motherboard was used as a template for marking around. The motherboard tray was then cut down to the markings using the tin snips. The razor sharp edges were then cleaned up with a file.
With the motherboard cut to size, the PCI backplate needed some work before it could be re-attached. One end was originally folded inside and I needed it to be folded the other way so I flattened it using a hammer…
…and then folded it outwards using a pair of pliers. Now the PCI backplate formed a tray which could be “sunk” into the new case.
Batten down the hatches…
