H&D2 Ammo Box Shuttles
H&D2 Ammo Box Shuttles Painting
The parts to be painted were primed. Note the masking tape on the handle grips. I wanted to keep the rubber grips black.
The only part of the DVD to be painted was the facia, as I wanted to maintain something of a black/green military feel.
Once the paint had cured, the front facias of the cases were prepared to have their mirrored fronts refitted. This consisted of cutting and applying double-sided tape to the facias.
The mirrored front refitted still with its protective film in place.
The I/O panel had also been masked to retain the black/green theme. Plus keeping the connector symbols meant that the case had lost no functionality.
Here are the finished painted handles and clasps ready for fitting to the cases:
The case sleeves were primed...
...and then spray painted followed by the handle and clasp being riveted in place.
A quick fitting to gauge how the overall effect is progressing.
