Hypercube² Part II Case Feet
CASE FEET
Every case needs casefeet, right? My point exactly ;-)
Hypercube² Part II Case Feet Hypercube² Part II Case Feet
I found these little babies under an old Pioneer amplifier that I don\'t use anymore. They are exactly what I need. In the second picture I dremeled out the inside honeycomb structure..
In the middle of every square I mounted one LED that comes out about 4 mm. The feet are easily attached to this LED - just slide them over end they will stay.
You can see the wiring for the bottom plate. A Luxeon in the center, to give a little bit more glow underneath. The four LEDs in the feet and around them a bunch of 3 mm LEDs (which were UV to start with, but I replaced them with white.)
Here are some 50mm plexi disks I made - they will go under the feet.
All four wired and working, but will the result be any good?
The effect looks like this: First OFF
Then ON!
