Hypercube² Part I Core Back Plate
CORE BACK PLATE
The back plate has room for a 80mm white LED fan, 6 x 3.5mm jacks and 5 holes at the bottom to get cables through for the two hard disks, the DVD drive and power to the top LEDs on the case. I didn\'t take alot of pictures how I made it, but I think you know how it goes.
Hypercube² Part I Core Back Plate Hypercube² Part I Core Back Plate
I had to get the four jacks in perfect alignment so they would plug in very easily when mounting the back panel. The solution was simple - a small piece of aluminium with four equally-spaced holes to hold the jacks the right distance apart.
Sweet!
The 80mm fan also needed a little modding. With my trusty Dremel I chopped one side of the fan, so it would fit through the round hole... or so I thought: I had to make the hole a lot bigger! In the photo below you can see my markings on the round hole. The fan will be mounted from the outside - this way I get a nice finish on the outside of the panel and a little bit more room on the inside of the core; I need all the space I can get on the inside, because it is going to be very cramped when everything is in place.
Time to put it all together: I finished off the fan with mounting bolts, each with a washer and a rubber grommet. Because this is an extraction fan to exhaust the hot air from inside the central core, I glued a large metal washer to the rotor hub to hide the green PCB inside.
Here is the core pictured from both ends: the baseplate will be bolted onto the core.
With all this ready, it was time for a testfitting:
My CAD drawings really paid off: everything fitted perfectly! In later pages I will talk about the fans you see in the back of the case and the toggle switches on the front - other work awaits me!
