Blackmesa II Part 1
The next stage was to install the hardware inside the case and to see how it matched.
Blackmesa II Part 1 Motherboard installation
I fitted a piece of bent aluminium checkerplate around the PCI slot openings. This sheet is held in place with screws.
I then made broken plastic parts out of this 3 mm thick, UV reactive Perspex sheet, and rusted the checkerplate PCI guard
Slowly but surely the case was starting to take shape.
I added more broken plastic to increase the \"smashed\" effect.
Here it is with the side panel in place
