Blackmesa II Part 1
Here are the paints I used to produce the rust effect. These are Modern Option paints, an iron basecoat and an oxidation solution.
Blackmesa II Part 1 The Rust Effect
Base colour dark grey spray paint.
The rust effects were made with a paintbrush rather than spraying. It required some practice to produce a truly authentic age damaged look.
First, the PSU...
...then the case
Blackmesa II Part 1 The Rust Effect Blackmesa II Part 1 The Rust Effect
The inside of the case was aged all over.
I even rusted up the fans.
