Blackmesa II Part 1
With the water-cooling colour theme decided, I selected parts like the motherboard and water-cooling tubing that complimented the planned orange colour scheme.
Blackmesa II Part 1 Specification
The DFI motherboard added just the right splash of colour.
I collected together all the parts I needed.
Of course, since this PC will be used to show off Half Life² to visitors at Valve Software\'s headquarters, I selected some of the best components available at the time:
Specification
  • Intel Pentium 4 3.0 GHz
  • DFI LANPARTY PRO875
  • ASUSTeK AX800 PRO/TD - 256 MO DVI/TV-Out
  • Corsair TwinX 1024 PC3200LL CAS2
  • Antec 1040 BII black w/ 400W PSU
  • Western Digital Raptor 36.7 Go 10,000 RPM SATA
  • Ortek Clavier Office Noir Qwerty
  • Logitech MX500 Performance Optical Mouse
Watercooling:
  • 1A-COOLING WATERBLOCK 1A-HV2
  • Eheim 1048 pump
  • AQUACOMPUTER Reservoir AQUATUBE REV 1.1 - TITANE
  • AQUACOMPUTER FIX RES PANEL
  • Black Ice II Xtreme Radiator
  • DOUBLE FANGRILL HTF2 (for above)
  • Tube 8X10 orange UV reactive
