Orac³ Part 1
Orac³ Part 1 Future-Cables
If you wondered what those big holes were for, it's all to do with an idea I had for cabling.
Orac³ Part 1 Future-Cables Orac³ Part 1 Future-Cables
Taking some hand shower kits I cut up the stainless steel hose with a hacksaw.
With rubber grommets stretched over the ends and heat shrink applied to seal sharp bits.
I shrunk it all with a heat gun and ended up with pretty good flexible conduit for wiring!
