Power on and the divider lights up perfectly! The light is even all around and looks even better in reality.
Here it is so far - basically a PSU, water reservoirs and a start on the front panel switches. Since I plan on going to the same effort on all the other components and following the same themes I think it will look pretty reasonable once finished.
The pass-thru of all the PSU wires to the attached junction box and detail of the fasteners securing the top plate of the case - 6mm cap screws, dome nuts and washers, all stainless steel.
Top of the case: The white LED in the front will be spotlighting the name of the case at the top of the front bezel.
Reservoirs with the hoses snaking past them.
Power Supply powered up.
The top of the case - pretty much complete but for the wiring up of a lot of jack plugs!
