Crysis
Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested with 2x anti-aliasing, but with anisotropic filtering disabled, and at a resolution of 1,680 x 1,050. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
Crysis
1,680 x 1,050 2x AA 0x AF, High Settings
  • MSI 890FXA-GD70
  • Asus Crosshair IV Formula
  • MSI 890GXM-G65 (BIOS 1.0)
  • Asus M4A89GTD Pro/USB
  • MSI 785GM-E65
    • 22
    • 39
    • 22
    • 39
    • 21
    • 42
    • 21
    • 40
    • 18
    • 40
20
30
40
Frame rate (fps), higher is better.
  • Minimum FPS
  • Average FPS
Crysis (Overclocked)
  • MSI 890FXA-GD70
  • MSI 785GM-E65
    • 27
    • 48
    • 26
    • 47
    • 25
    • 48
    • 25
    • 46
    • 24
    • 44
20
30
40
50
  • Minimum FPS
  • Average FPS
Read how to overclock the MSI 890FXA-GD70, or our Performance Analysis.
