Crysis
Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested without anti-aliasing or anisotropic filtering enabled, and at a resolution of 1,680 x 1,050. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel if you wish.
Crysis
1,680 x 1,050 2x AA 0x AF, High Settings
  • Asus Crosshair IV Formula
  • MSI 890FXA-GD70
  • MSI 890GXM-G65 (BIOS 1.0)
  • Asus M4A89GTD Pro/USB
  • MSI 785GM-E65
    • 22
    • 39
    • 22
    • 39
    • 21
    • 42
    • 21
    • 40
    • 18
    • 40
20
30
40
Frame rate (fps), higher is better.
  • Minimum FPS
  • Average FPS
Crysis (Overclocked)
  • MSI 890FXA-GD70
  • MSI 785GM-E65
    • 27
    • 48
    • 26
    • 47
    • 25
    • 48
    • 25
    • 46
    • 24
    • 44
20
30
40
50
  • Minimum FPS
  • Average FPS
Read how to overclock the Asus Crosshair IV Formula, or our Performance Analysis
SATA Performance
Website: HD Tach 3.0
We tested the SATA and performance with an Intel X25-M SSD to maximise the use of the SATA connections and reveal any differences in performance. We used the Quick test of HDTach 3.0, and recorded the average read speed.
SATA Performance (Internal)
HDTach 3.0.1.0, 8MB Zone Test, Average Read
  • MSI 890FXA-GD70
  • MSI 785GM-E65
    • 218
    • 0
    • 218
    • 165
    • 208
    • 0
    • 184
    • 165
    • 0
    • 207
100
150
200
250
MB/sec, ranked by SATA 6Gbps (higher is better)
  • SATA 6Gbps
  • SATA 3Gbps
USB Performance
We tested the USB performance with an Intel X25-M SSD and a SATA to USB adapter to saturate the USB bus in order to look for any performance drops.
USB Performance
  • MSI 890FXA-GD70
  • MSI 785GM-E65
    • 35
    • 192
    • 33
    • 117
    • 28
    • 101
    • 27
    • 82
    • 31
    • 0
100
150
200
MB/sec, ranked by USB 3 (higher is better)
  • USB 2
  • USB 3
