MSI Big Bang-FUZION: Lucid Hydra arrives
January 8, 2010 | 09:06
Tags: #200 #bang #benchmark #big #cards #crossfire #fusion #fuzion #gpu #hardware #lucid #lucid-hydra #mix #motherboard #multi #perform #performance #results #sli
Companies: #msi #test
Mixed ATI GPU Performance
We did the same thing for ATI graphics cards as well: We mixed and matched to see the performance difference against two identical cards. We also compared using two different graphics cards to just single cards, in order to show any performance advantage.
Batman: Arkham Asylum (ATI Mix)
1680x1050 0xAA 0xAF 64-bit DX9 Highest Settings, V-Sync off
  • Radeon HD 5770 1GB
  • 2x Radeon HD 5770 1GB Hydra
  • Radeon HD 5870 1GB and Radeon HD 5750 1GB Hydra
  • Radeon HD 5770 1GB and Radeon 4770 512MB Hydra
    • 61.8
    • 57.0
    • 61.1
    • 50.0
    • 61.3
    • 38.0
    • 59.9
    • 19.0
20
30
40
50
60
FPS (arranged by min FPS)
  • Average FPS
  • Minimum FPS
Fallout 3 (ATI Mix)
1680x1050 4xAA 16xAF DX10 Ultra High Settings
  • Radeon HD 5870 512MB and Radeon HD 5750 512MB Hydra
    • 82.4
    • 53.0
    • 70.8
    • 35.0
    • 69.6
    • 35.0
    • 69.7
    • 34.0
20
30
40
50
60
70
80
90
  • Average FPS
  • Minimum FPS
Call of Duty 4: Modern Warfare (ATI Mix)
1680x1050 4xAA 16xAF DX9 Highest Settings
    • 78.5
    • 54.0
    • 52.6
    • 39.0
    • 51.0
    • 38.0
    • 46.7
    • 33.0
20
30
40
50
60
70
80
  • Average FPS
  • Minimum FPS
Team Fortress 2 (ATI Mix)
    • 152.5
    • 104.7
    • 104.3
    • 103.4
50
75
100
125
150
  • Average FPS
In Batman and Call of Duty 4 it's the same old story, however Fallout 3 sees a nice increase in performance from the HD 5870 and 5750, although given the HD 5770, two HD 5770s and HD 5770+4770 yield identical scores, we could also put that down to just the extra grunt of the 5870 alone. In the Team Fortress 2 stakes, again we see a linear example of how the HD 5770 scores one result and the HD 5870 scores a faster result. The extra cards again make no difference.
Is it simply running only one card? We double checked Hydra and both graphics cards were installed correctly and enabled, of which they were, and the results were consistent across multiple runs. Extra cards don't make a difference, defeating the point of Hydra.
