Foxconn Blood Rage
AutoMKV x.264 Encoding
Website: Doom9
We tested x.264 compression using AutoMKV version 0.97.1 to compress a 1.1GB DVD VOB file into 350MB MP4 file using a two-pass encode and we used a 112kbps LAME encoder to compress the audio. The whole process is dependent on both single and multi-core performance and the entire encoding time was recorded.
There's quite a shift to using MKV or MP4 wrappers for x264 content now, especially for movie content and those in the large anime fansubbing community. x264 doesn't have the same SSE enhancements as some other codecs, but the benefits of extra cache and better memory performance should still show notable improvements.
x.264 Encoding
AutoMKV 0.97.1, 1.05GB MPEG-2 VOB to 350MB x264 .mp4, LAME MT 112Kbps
  • Gigabyte GA-EX58-UD4P
  • MSI Eclipse SLI
  • Gigabyte GA-EX58-DS4
  • Asus P6T Deluxe
  • Foxconn Blood Rage
  • 544.0
  • 544.0
  • 548.0
  • 549.0
  • 556.0
200
300
400
500
600
Time in Seconds (lower is better)
The Blood Rage can't seem to keep up with the other boards in our AutoMKV video encode test, and it was consistently several seconds behind the rest of the pack in performance, dropping it to the bottom of the table.
Handbrake H.264 Encoding
Website: HandBrake
Our test uses Handbrake - an open-source, GPL-licensed, multiplatform, multithreaded video transcoder, available for MacOS X, Linux and Windows - to encode a high resolution MPEG-2 video using the H.264 codec. This primarily tests multi-threaded CPU and memory subsystem performance.
Handbrake h.264 Video Encoding
CustomPC Benchmark
  • MSI Eclipse SLI
  • Asus P6T Deluxe
  • 390
  • 393
  • 393
  • 393
  • 398
200
300
400
Again, in Handbrake h.264 video encoding the Foxconn drops down the table and sits at the bottom - it's several seconds behind the rest of the boards tested.
GIMP Image Editing
Website: GUN Image Manipulation Program (GIMP)
Our GIMP image editing test simulates how well a PC can manipulate a collection of large digital photos, and to achieve a low time requires a PC with a powerful CPU, plenty of quick memory and efficient hard disk drive access.
GIMP Image Editing Test
CustomPC Benchmark
  • MSI Eclipse SLI
  • Asus P6T Deluxe
  • 327
  • 327
  • 331
  • 335
  • 339
100
150
200
250
300
350
The core Blood Rage performance is a little better here, but it barely exceeds the core performance of the Gigabyte DS4 board which is a fraction of its price, and still can't keep up with more expensive boards like the P6T Deluxe and Eclipse which are several seconds faster.
