Lavalys Everest 4.60.1540 Beta Memory Performance
Website: Lavalys
Everest Memory Performance Test
  • Foxconn Blood Rage
  • Gigabyte GA-EX58-DS4
  • Asus P6T Deluxe
  • MSI Eclipse SLI
  • Gigabyte GA-EX58-UD4P
    • 14282
    • 12111
    • 14339
    • 12737
    • 9732
    • 13795
    • 12388
    • 9630
    • 14075
    • 12159
    • 9637
    • 13771
    • 12113
    • 9620
    • 13467
5000
7500
10000
12500
15000
MB/s (higher is better)
  • Read (MB/s)
  • Write (MB/s)
  • Copy (MB/s)
Everest Memory Latency Test
  • Asus P6T Deluxe
  • MSI Eclipse SLI
  • 36.9
  • 37.9
  • 38.1
  • 38.1
  • 38.7
20
30
40
Nanoseconds (lower is better)
In single-threaded performance with Everest, the Foxconn somehow manages to nail every other board we've tested. This result is absoultely consistent across multiple triple-channel memory kits from G.Skill and Corsair - we triple checked and reset the memory timings to make sure everything was consistent. It looks like Foxconn has done something to nail the raw memory performance in Everest at least edging out a four to 24 percent performance increase across all three tests. In comparison the latency numbers are pretty normal though and because Foxconn automatically slows the CAS latency from 5 to 6 (BIOS to CPU-Z reading) it matches most of the other boards that do this too, meaning it has a little more latency than the Asus board which keeps it at CAS-5 at 1,066MHz.
SiSoftware Sandra Lite 2009.SP1 Beta (15.42)
Website: Sisoftware
Sisoft Sandra Unbuffered Memory Test
  • Asus P6T Deluxe
  • MSI Eclipse SLI
  • 20180.3
  • 20037.8
  • 19918.2
  • 19896.5
  • 19845.0
10000
15000
20000
Sisoft Sandra Random Memory Latency Test
  • Asus P6T Deluxe
  • MSI Eclipse SLI
  • 72
  • 73
  • 74
  • 74
  • 74
20
30
40
50
60
70
80
The Foxconn doesn't fare as well as the others in multi-threaded Sisoft Sandra, although there's very little difference down the table in both raw bandwidth and latency.
