Adobe Photoshop Elements 4.0
For our Photoshop Elements test, we used a selection of 400 three megapixel photographs taken in a variety of surroundings using the batch file processing function in the Elements Editor. We performed all of the auto fixes, including Auto Levels, Auto Contrast, Auto Colour and Sharpen before resizing the image to 640x480 and saving as a high quality JPEG.
  • J&W Minix 780G (AMD 780G/SB700)
  • Jetway JNC62K (GeForce 8200)
    • 532.5
    • 662.5
    • 538.0
    • 662.5
200
300
400
500
600
700
Time in Seconds (lower is better)
  • Athlon 64 X2 BE-2350
  • Sempron LE-1200
On average, the performance of both boards, with both dual and single core CPUs, is virtually identical despite the fact that the J&W MINIX is running dual channel memory compared to the Jetway's single channel limit.
File Compression & Encryption:
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt the MPEG-2 source file from our video encoding test with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs used in our Photoshop Elements test with the same compression settings.
Large File Compression & Encryption
WinRAR 3.71, Multithreaded, 276MB source file
    • 243.5
    • 693.5
    • 242.0
    • 659.0
200
300
400
500
600
700
  • Sempron LE-1200
Small File Compression & Encryption
WinRAR 3.71, Multithreaded, 400 2048x1536 Photos
    • 213.5
    • 381.5
    • 210.0
    • 367.0
200
300
400
  • Sempron LE-1200
With a dual core CPU there's virtually no difference again, however with a single core Sempron the J&W falls behind by a quite significant 14 and 34 seconds compared to the Jetway.
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
Large File Decompression & Decryption
    • 24.0
    • 24.0
    • 23.0
    • 24.0
10
15
20
25
  • Sempron LE-1200
Small File Decompression & Decryption
    • 38.0
    • 40.0
    • 38.5
    • 40.5
20
30
40
  • Sempron LE-1200
Decompression performance is again almost identical and agnostic of whether a single or dual core CPU is being used. Memory performance or even chipset choice obviously do not play a significant factor in affecting this result on these platforms.
Xvid Encoding:
We tested video encoding performance using VirtualDub-MPEG version 1.6.15 and a multithreaded version of the Xvid codec, along with the LAME MT MP3 encoder for encoding audio. We did a two-pass encode of a 15-minute 276MB digital TV recording with a target file size of 100MB.
Xvid Encoding
VirtualDub MPEG-2 1.6.15, Xvid 1.2 beta, 276MB .mpg to 100MB .avi
    • 1354.5
    • 1660.0
    • 1356.5
    • 1653.5
500
750
1000
1250
1500
1750
  • Sempron LE-1200
Again there's very little difference between both the boards - a couple of seconds in favour of the Jetway at best between either single or dual core CPUs.
