Gigabyte GA-MA790GP-DS4H
SATA and eSATA Performance
Website: HD Tach 3.0
HDTach 3.0.1.0, 8MB Zone Test, Average Read
  • Gigabyte GA-MA790GP-DS4H (SB750)
  • Asus M3A32-MVP Deluxe (SB600)
  • Asus CrossHair II (nForce 780a)
  • Gigabyte GA-MA78G-DS3H (SB700)
    • 82.0
    • 82.0
    • 82.0
    • 81.5
    • 81.9
    • 0.0
    • 81.4
    • 81.4
20
30
40
50
60
70
80
90
MB/s (higher is better)
  • SATA
  • eSATA
SATA performance sees a fractional improvement to a solid 82MB/s regardless of IGP use taking up some subsystem resources. In comparison the SB700 and SB600 are fractionally slower, and the IGP has a slight effect. Either way, this is exactly what we'd expect to see from SATA - it matches other chipsets.
USB 2.0 Performance
USB 2.0 Performance
  • 34.6
  • 28.6
  • 27.6
  • 26.5
10
15
20
25
30
35
There are no words other than "epic fail" to describe AMD's USB 2.0 performance. We thought it was an error at first - that we were missing something, but after double checking the drivers, having no issue what-so-ever with connectivity on USB and talking to AMD, this is simply the actual performance.
So much for claiming things got better with SB700 - if anything, they've got worse and SB600 wasn't exactly great to start with!
A good MCP/ICH chipset like those from Nvidia or Intel will max out the USB 2.0 potential at 34.6MB/s exactly, when we connect up a hard drive to it and flood the bus. Those from AMD simply whither.
