Asus CrossHair II Formula and Hybrid SLI
August 15, 2008 | 12:15
Tags: #780a #8200 #analysis #benchmarks #consumption #crosshair #ddr2 #formula #geforce #hybrid #ii #motherboard #nforce #power #republic-of-gamer #review #rog #sli
Companies: #asus
Power Consumption
In an apples to apples comparison of the nForce 780a SLI MCP versus the AMD 780G, the single chip 780G mGPU on the Gigabyte motherboard is 30W lower than the 780a on the CrossHair II Formula at idle. With Hybrid Graphics the 780a+8500 GT again uses considerably more power than the 780G+HD 3450 solution, but as we've shown previous actually performs less.
When we're talking about Hybrid Power though, this is where the Nvidia 780a really saves the power - cutting 25W off at idle and virtually matching the power use under load, bar a couple of watts more.
Compared to the 790FX with the higher power Phenom X4 9850E in the driving seat, the boards are pretty matched in terms of power - the Asus M3A32-MVP Deluxe has a 4W higher idle power than the CrossHair II Formula, but it's also 6W lower power under load.
Power Consumption
Power at wall socket. BIOS Defaults, all onboard hardware enabled. Windows Desktop Idle, Prime95 Loa
  • Gigabyte GA-MA78G-DS3H (mGPU) (8750)
  • Asus CrossHair II Formula (mGPU) (8750)
  • Gigabyte GA-MA78G-DS3H (Hybrid Graphics) (8750)
  • Asus CrossHair II Formula (Hybrid Graphics) (8750)
  • Gigabyte GA-MA78G-DS3H (PCI-Express) (8750)
  • Asus CrossHair II Formula (mGPU) (9850BE)
  • Asus CrossHair II Formula (PCI-Express) (8750)
  • Asus M3A32-MVP Deluxe (PCI-Express) (9850BE)
  • Asus CrossHair II Formula (Hybrid Graphics) (9850BE)
  • Asus CrossHair II Formula (PCI-Express) (9850BE)
    • 77
    • 164
    • 105
    • 167
    • 92
    • 174
    • 118
    • 183
    • 129
    • 215
    • 103
    • 217
    • 105
    • 218
    • 160
    • 266
    • 107
    • 268
    • 156
    • 272
100
150
200
250
300
Watts (lower is better)
  • Idle
  • Load
