Jetway JNC62K (GeForce 8200 on mini-ITX)
Test Setup:
As always, we did our best to deliver a clean set of benchmarks, with each test repeated three times and an average of those results is what we’re reporting here. In the rare case where performance was inconsistent, we continued repeating the test until we got three results that were consistent.
Motherboards:
  • Jetway JNC62K (Nvidia GeForce 8200)
  • Gigabyte GA-MA78GM-S2H (AMD 780G)
  • Asus P5E-VM HDMI (Intel G35)
  • Gigabyte GA-73PVM-S2H (Nvidia GeForce 7100)
  • MSI K9AGM3-FIH (AMD 690G)
Common Components:
  • Intel Core 2 Duo E4300
  • AMD Athlon 64 5000+ 65nm Energy Efficient
  • 2GB DDR2 800MHz at 5-5-5-18-2T timings (SDP)
  • Corsair VX550W PSU
  • Seagate 7200.10 200GB SATA hard drive
  • Windows Vista Home Premium 32-bit
Drivers
  • Nvidia Forceware 169.25
  • Intel IGP Drivers 15.7.3
  • AMD Catalyst 8.3 RC3
  • Cyberlink PowerDVD Ultra, Build 3730
Jetway JNC62K (GeForce 8200 on mini-ITX) Test Setup
While the other board featured used 2x1GB of memory in dual channel, we had to use a single 2GB stick with the Jetway board. It's worth noting that while the memory bandwidth is decreased because of the drop from dual to single channel memory, the efficiency of single channel memory is greater and the density of the single 2GB memory DIMM is higher. The memory timings and speed were kept consistent, however.
