AMD Radeon R9 Fury X Review
June 24, 2015 | 12:59
Tags: #amd-radeon-r9-fury-x-review #fiji #r9-300-series #radeon-r9-fury-x
Companies: #amd
AMD Radeon R9 Fury X 4GB Overclocking Results
You can overclock the R9 Fury X in the Catalyst Control Centre or in third party applications like MSI Afterburner. We chose the latter for its direct clock speed readings rather than CCC's percentage increase sliders. We set the power target to its maximum (a massive 150 percent) and left everything else as it was – the target temperature was already at its maximum of 75°C.
With these settings, we were only able to add 80MHz to the clock speed for a final reading of 1,130MHz before we ran into stability issues. This equates to just under 8 percent; not that impressive if we're being honest. There's also no ability to overclock the memory. AMD's reasoning here is that there's simply no need for it, claiming that even at high detail 4K gaming you won't be able to fill the bandwidth of the card as it comes. The results of our efforts can be seen below.
Overclocking - Battlefield 4
3,840 x 2,160, 'Ultra' Settings, 0x MSAA
  • AMD Radeon R9 Fury X 4GB (OC)
  • Nvidia GeForce GTX 980 Ti 6GB
  • Nvidia GeForce GTX 980 4GB
  • AMD Radeon R9 290X 4GB
    • 40
    • 51
    • 39
    • 49
    • 38
    • 55
    • 30
    • 43
    • 28
    • 37
20
30
40
50
60
Frames Per Second
  • Minimum
  • Average
Overclocking - Middle Earth: Shadow of Mordor
3,840 x 2,160, 'Very High' Settings
    • 44
    • 54
    • 43
    • 53
    • 43
    • 52
    • 34
    • 42
    • 33
    • 41
20
30
40
50
60
Frames Per Second
  • Minimum
  • Average
Overclocking - Unigine Valley 1.0
2,560 x 1,440, 'Ultra' Quality, 0x AA
    • 3963
    • 3460
    • 3283
    • 3088
    • 2443
2000
3000
4000
Score (higher is beter)
  • Score
