Putting realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something we've experimented here at bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how GPU will be used when gaming.
It's such a hardcore test that any GPU under test is almost guaranteed to hit its thermal limit, the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game like Crysis running at a certain point also isn't reflective of real world use. There's no guarantee that the GPU is being pushed as hard as other titles might do, and the load will vary from play through to play through.
Eventually then, we've decided to use 3DMark06's Canyon Flight test as a real world representative, repeatable graphics test. It's a ferociously demanding test, pushing graphics cards to their limit, but also containing peaks and troughs in performance that match real world game play.
As the test is so demanding and GPU limited, we've set 3DMark to run the test at 1,280 x 1,024 with 0xAA and 16xAF (enabled in the driver), constantly looping the test for thirty minutes and recording the maximum power consumption and GPU Delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
Power Consumption (idle)
Windows 7 Desktop (Aero enabled) Idle Power Usage
AMDRadeon HD 6870 1GB
AMD Radeon HD 5770 1GB
Nvidia GeForce GTX 460 768MB
AMD Radeon HD 6850 1GB
AMD Radeon HD 5870 1GB
AMD Radeon HD 5850 1GB
Nvidia GeForce GTX 560 Ti 1GB
Nvidia Geforce GTX 460 1GB
AMD Radeon HD 6950 2GB
AMD Radeon HD 6970 2GB
Nvidia GeForce GTX 570 1.3GB
Nvidia GeForce GTX 580 1.5GB
Nvidia GeForce GTX 470 1.2GB
AMD Radeon HD 5970 2GB
Nvidia GeForce GTX 480 1.5GB
128
129
130
131
136
136
135
137
138
141
150
150
160
163
164
50
75
100
125
150
175
Watts at socket, lower is better
Power Consumption (load)
3DMark06 Canyon Flight test, 1,280 x 1,024 0xAA 16xAF, Load Power Usage
AMD Radeon HD 6870 1GB
212
229
238
245
247
256
270
270
285
306
330
341
347
363
376
200
300
400
Thermal Performance
Heat (idle)
Windows 7 Desktop (Aero Enabled)
8
10
11
14
14
15
18
19
19
20
20
22
23
25
28
10
15
20
25
30
Delta T in °C
Heat (peak)
3DMark06 Canyon Flight test, 1,280 x 1,024 0xAA 16xAF, Peak Temperature
38
44
46
46
46
46
46
50
50
54
54
55
56
72
72
20
30
40
50
60
70
80
Delta T in °C
For explanation of what these numbers mean, head to the Results Analysis page.
