As always we've aimed to test the systems in likely, real-world scenarios that integrated graphics would be used for. We manual played the games and recorded the FPS using FRAPS 3.03, preferring to use games and a 1,280 x 800 resolution likely used by HDTVs and scaled down from mainstream, widescreen TFT sizes: 19in to 21in.
For the video playback testing, we used h.264 clips, trailers and Blu-ray discs, in popular paid-for and free softwares, to measure CPU usage and power consumption in all the platforms. During these tests, the PSU listed below was replaced with a 350W Enermax Eco80 in order to represent a typical, low power and budget ATX PSU that could be paired with these PCs. We also used an Iiyama 21in FullHD (1,920 x 1,080) monitor with HDCP (over DVI) in the Blu-ray playback tests.
DFI LANParty Jr. GF9400-T2RS (GeForce 9400 IGP at 580MHz/1,400MHz, 421 BIOS)
Common Components
Seagate Barracuda 7200.12 1TB hard disk
PC Power and Cooling Silencer 750W PSU
Windows 7 Home Premium x64
Intel 15.16.5.64.2021 WHQL
GeForce Driver 196.21 WHQL
ATI Catalyst 9.12 WHQL
System Cost
Please note, we did not feel the need to unify the clock speeds on the test systems - instead testing the fast, dual core CPUs at their default clock speed. This is because the CPU architectures - and therefore IGPs - cannot be directly compared clock for clock.
Be aware of the cost difference between the AMD system and rival Intel ones, which should factor into any system upgrade: for the cost of the Intel system you could buy the AMD one with quite a powerful a discrete graphics card, clearly allowing far superior performance. However, this article is designed for those aiming to buy an IGP for video playback - for ultra low power, the lowest physical profile and silence, for example - yet wanting some gaming on the side.
System Cost and 2D Performance
CustomPC Benchmark
Intel GMA HD (Core i5 661: 900MHz IGP)
Intel GMA HD (Core i3 530: 733MHz IGP)
Nvidia GeForce 9400 (Core 2 Duo E8500)
AMD 785G (Phenom II X2 550 BE)
1313
255
1178
185
1044
235
1009
150
500
750
1000
1250
1500
Sorted by Overall Score
CPC Bench Overall Score
CPU & Motherboard Cost (£)
The cost of the Intel Core i5-661 alone is £170, which in itself is more expensive than the price of the AMD CPU and 785G motherboard, which are £70 and £80 respectively. Throw in the Gigabyte GA-H55M-UD2H motherboard for the Intel CPU, at £85, and that comes to a whopping £255! For the £100 difference between the Core i5-661 and AMD's setup, you could drop in a Radeon HD 5750 for an awesome gaming experience.
The slightly cheaper Core i3-530 comes in at £100, saving a solid £70 off the end price but it's still more expensive than the AMD setup. Notably, for £30, you cannot buy an additional GPU worth mentioning though.
So why did we go with the Phenom II X2 550 Black Edition and not its Phenom II X4 965 (which would STILL be cheaper than Intel's premium system)? We didn't want to use a 125W TDP CPU - it's against the "low power" ethos of integrated graphics - however we did want a powerful dual-core in the driving seat so this was the best compromise we could find.
Finally, harking back to the days of Core 2 Duo - you can still buy the Core 2 Duo E8500 for around £125, however the DFI LANParty Jr featuring the GeForce 9400 chipset, like all GeForce 9300 and 9400 motherboards, is now extinct. At the time it retailed for around £110, and we've included it for a comparison.
