Even after almost two years since it's release Crysis will make your system cry - it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under DirectX 10 mode with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 16x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 4xAA and 2,560 x 1,600 with 0xAA and 4xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
Crysis
1,280 x 1,024 0xAA 16xAF, DirectX 10, High Quality
ATI Radeon HD 5750 1GB
ATI Radeon HD 4770 512MB
Sapphire ATI Radeon HD 5670 1GB
ATI Radeon HD 5670 512MB
Nvidia GeForce 9800GT 512MB
Nvidia GeForce GT 240 512MB
31
16
30
15
23
11
22
11
28
10
22
8
10
15
20
25
30
35
Frames Per Second
Average
Minimum
Crysis
1,280 x 1,024 4xAA 16xAF, DirectX 10, High Quality
27
13
23
11
19
9
19
9
23
8
18
7
10
15
20
25
30
Frames Per Second
Average
Minimum
Crysis
1,680 x 1,050 0xAA 16xAF, DirectX 10, High Quality
26
14
23
12
18
9
18
9
23
4
17
4
10
15
20
25
Frames Per Second
Average
Minimum
Crysis
1,680 x 1,050 4xAA 16xAF, DirectX 10, High Quality
22
11
19
9
16
8
15
7
17
4
13
10
15
20
25
Frames Per Second
Average
Minimum
For analysis of these results, please read the Results Analysis page.
