MSI N260GTX Lightning Review
Written by Mark Mackay
July 6, 2009 | 10:15
Tags: #55nm #geforce #gtx-260 #lightning #maxcore #n260gtx #overclockable #review
Companies: #msi #nvidia
S.T.A.L.K.E.R.: Clear Sky
Publisher: Deep Silver
S.T.A.L.K.E.R.: Clear Sky is the prequel to GSC Game World's sleeper hit S.T.A.L.K.E.R.: Shadow of Chernobyl and was unfortunately released in a bizarrely unfinished state and it's taken some time for the game to reach the levels of stability that we expect from a game. However, with the new 1.5.07 patch, Clear Sky runs great and as you would expect it to.
Clear Sky uses a heavily tweaked version of the X-Ray engine, which debuted with Shadow of Chernobyl and was updated to support several new graphical effects using DirectX 10 (and later DirectX 10.1 through the 1.5.06 patch). The improvements include enhanced visual effects like 'God Rays', wet surfaces, volumetric light and smoke, depth of field blurring, and screen space ambient occlusion lighting as well as better textures.
We used a custom timedemo for our testing, which incorporates many of the advanced effects introduced with DirectX 10 – we also enabled DirectX 10.1 on the Radeons. However, due to the intensity of engine, we have set the in game details to "High" instead of "Maximum" and have left anti-aliasing disabled for the time being.
MSI N260GTX Lightning Review S.T.A.L.K.E.R.: Clear Sky MSI N260GTX Lightning Review S.T.A.L.K.E.R.: Clear Sky MSI N260GTX Lightning Review S.T.A.L.K.E.R.: Clear Sky
1,280 x 1,024 0xAA 16xAF, DirectX 10/10.1, High Detail
  • ATI Radeon HD 4870 X2 2GB
  • Sapphire Radeon HD 4890 1GB Atomic
  • Nvidia GeForce GTX 285 1GB
  • ATI Radeon HD 4890 1GB
  • Asus Radeon HD 4890 1GB
  • Nvidia GeForce GTX 275 896MB
  • MSI N260GTX Lightning
  • Nvidia GeForce GTX 260-216 896MB
    • 75.4
    • 54.0
    • 50.7
    • 35.0
    • 45.9
    • 35.0
    • 44.7
    • 32.0
    • 44.7
    • 32.0
    • 43.9
    • 33.0
    • 40.0
    • 30.0
    • 39.6
    • 30.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
1,680 x 1,050 0xAA 16xAF, DirectX 10/10.1, High Detail
    • 65.7
    • 38.0
    • 42.6
    • 25.0
    • 41.2
    • 31.0
    • 37.6
    • 29.0
    • 35.6
    • 26.0
    • 35.6
    • 26.0
    • 35.4
    • 27.0
    • 32.7
    • 25.0
20
30
40
50
60
70
Frames Per Second
  • Average
  • Minimum
1,920 x 1,200 0xAA 16xAF, DirectX 10/10.1, High Detail
    • 56.7
    • 38.0
    • 38.5
    • 31.0
    • 33.7
    • 26.0
    • 33.7
    • 26.0
    • 31.1
    • 22.0
    • 29.8
    • 22.0
    • 27.3
    • 22.0
    • 27.2
    • 21.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
2,560 x 1,600 0xAA 16xAF, DirectX 10/10.1, High Detail
  • Asus ATI Radeon HD 4890 1GB
    • 35.7
    • 28.0
    • 27.3
    • 14.0
    • 24.3
    • 21.0
    • 21.1
    • 18.0
    • 21.1
    • 18.0
    • 20.3
    • 16.0
    • 19.1
    • 15.0
    • 16.8
    • 13.0
20
30
40
Frames Per Second
  • Average
  • Minimum
The only resolution that the Lightning managed a playable frame rate in S.T.A.L.K.E.R.: Clear Sky was 1,280 x 1,024 and even then its 30fps minimum was beaten by all the other cards on test. While the Lightning's average frame rates where good as we pushed the resolution up, it still couldn't hit a smooth minimum frame rate of above 25fps so slowdown was still noticeable regardless of decent average. The high averages are likely to be because of the enormous amount of memory the Lightning is endowed with. Raising the resolution from 1,920 x 1,200 to 2,560 x 1,600 for example, didn't effect the average frame rate whatsoever while the minimum took a hefty hit.
