Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under DirectX 10 mode with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27 to 33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game and tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4x anti-aliasing, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction with Very High quality in-game settings, we'll be pushing even the bleeding edge hardware on test to the limit.
Crysis
1,280 x 1,024 0xAA 16xAF, DirectX 10, High Quality
Nvidia GeForce GTS 250 512MB
ATI Radeon HD 4850 512MB
Nvidia GeForce 9800 GT 512MB
Gigabyte ATI Radeon HD 4770 512MB
XFX GeForce 9600 GSO XXX Edition 384MB
ATI Radeon HD 4830 512MB
39.9
22.0
33.4
17.0
29.9
16.0
29.3
15.0
29.2
15.0
26.2
15.0
23.9
12.0
20
30
40
Frames Per Second
Average
Minimum
Crysis
1,280 x 1,024 2xAA 16xAF, DirectX 10, High Quality
32.5
20.0
28.3
14.0
25.9
17.0
26.0
13.0
25.8
13.0
21.8
11.0
21.7
12.0
10
15
20
25
30
35
Frames Per Second
Average
Minimum
Crysis
1,280 x 1,024 4xAA 16xAF, DirectX 10, High Quality
29.3
17.0
25.6
12.0
23.8
12.0
23.3
11.0
23.2
11.0
20.2
10.0
10
15
20
25
30
Frames Per Second
Average
Minimum
Crysis
1,680 x 1,050 0xAA 16xAF, DirectX 10, High Quality
31.0
19.0
25.4
14.0
24.5
15.0
23.3
12.0
22.3
12.0
20.1
11.0
19.2
10.0
10
15
20
25
30
35
Frames Per Second
Average
Minimum
Crysis
1,680 x 1,050 4xAA 16xAF, DirectX 10, High Quality
21.7
11.0
20.1
10.0
18.9
9.0
18.5
9.0
18.5
10.0
16.1
8.0
10
15
20
Frames Per Second
Average
Minimum
Crysis
1,920 x 1,200 0xAA 16xAF, DirectX 10, High Quality
25.1
15.0
22.6
13.0
21.0
12.0
20.5
11.0
19.8
12.0
17.3
9.0
16.8
9.0
10
15
20
25
Frames Per Second
Average
Minimum
Crysis
1,920 x 1,200 4xAA 16xAF, DirectX 10, High Quality
23.8
11.0
20.0
11.0
18.6
10.0
18.1
9.0
16.6
8.0
16.0
8.0
10
15
20
25
Frames Per Second
Average
Minimum
First up in the benchmarks is the super demanding Crysis. The Gigabyte produced practically identically to the reference design, with barely a frame per second difference between the two cards.
