Sapphire Radeon HD 4870 2GB Vapor-X
Written by Clive Webster
April 14, 2009 | 13:20
Tags: #2gb #benchmark #cod5 #crysis #custom-cooler #folding #gtx-275 #hd-4870 #hd-4890 #heat #power #radeon #review #vapor-x #vapour-x
Companies: #ati #sapphire #test
Power Consumption (Idle and Gaming)
We tested the power consumption with a Watts Up? Pro power meter, using the device to record the total system power consumption at the wall socket, while we ran three sets of four runs of Crysis in DX10 at 1920x1200.
Using the data recorded by the meter we could determine the peak output, the consistent minimum and the average load over the entire run of tests.
As both ATI and Nvidia test benches are now identical Core i7 systems, we can accurately determine the apples to apples difference of what power both PCs take to run.
Power Consumption (Idle)
Windows Vista Desktop (Aero Enabled)
  • Nvidia GeForce GTX 275 896MB
  • Nvidia GeForce GTX 260-216 896MB
  • Nvidia GeForce GTX 285 1GB
  • Sapphire Vapor-X HD 4870 2GB
  • ATI Radeon HD 4870 1GB
  • ATI Radeon HD 4890 1GB
    • 167
    • 190
    • 196
    • 203
    • 208
    • 222
100
150
200
250
Power at socket (W)
  • Power Consumption (W)
Power Consumption (Peak)
Crysis DX10 at 1,920 x 1,200 0xAA 16xAF, Peak Power Usage
    • 282
    • 295
    • 302
    • 317
    • 339
    • 364
200
300
400
Power at socket (W)
The power saving of the Sapphire Vapor-X when idle is likely due to the more advanced VRMs and the lower RPM fan.
Under load, these factors become more evident - the Vapor-X has an extra 1GB of memory to power and yet only consumes 13W more than the reference card. It helps that the fan of the Vapor-X never has to blow particularly hard to dissipate the heat from the vapour chamber cooler.
