As always, we did our best to deliver a clean set of benchmarks, with each test repeated three times and an average of those results is what we’re reporting here. In the rare case where performance was inconsistent, we continued repeating the test until we got three results that were consistent.
The tests performed are a mixture of custom in-game timedemos and manually played sections with FRAPS to record the average and minimum frame rates. We strive to not only record real-world performance you will actually see, but also present the results in a manner that is easy to digest.
Rather than testing these mid-range cards on our ultra-high end Intel Core i7 test systems, we decided to instead test them in a much more mainstream system. This is because cards like these will, in all likelihood, never end up in a high end system, and using one would have likley skewed the results unrealistically. So here's our mid-range graphics system, which while a little less impressive than out usual graphics test benches, should still produce reliable results without giving too many aspirations of grandeur for those not running ultra high end kit.
Mid-Range Graphics Test System
Intel Core 2 Duo E6850 (operating at 3.00GHz – 9x333MHz)
