Sapphire ATI Radeon HD 4850 X2 2GB
Written by Tim Smalley
January 23, 2009 | 09:20
Tags: #2gb #4850 #analysis #board #card #design #drivers #evaluation #gddr3 #hd #performance #r700 #radeon #review #rv770 #x2
Companies: #amd #ati #sapphire #test
Power Consumption
We tested the power consumption with a Watts Up? Pro power meter, using the device to record the total system power consumption at the wall socket, while we ran three sets of four runs of Crysis in DX10 at 1920x1200.
Using the data recorded by the meter we could determine the peak output, the consistent minimum and the average load over the entire run of tests.
As both ATI and Nvidia test benches are now identical Core i7 systems, we can accurately determine the apples to apples difference of what power both PCs take to run.
Power Consumption (idle)
Windows Vista Desktop (Aero Enabled)
  • Nvidia GeForce GTX 260-216 896MB
  • Nvidia GeForce GTX 285 1GB
  • Nvidia GeForce GTX 280 1GB
  • Nvidia GeForce GTX 295 1,792MB
  • Nvidia GeForce GTX 260-216 896MB SLI
  • ATI Radeon HD 4870 1GB
  • Sapphire ATI Radeon HD 4850 X2 2GB
  • ATI Radeon HD 4870 512MB
  • Nvidia GeForce GTX 280 1GB SLI
  • ATI Radeon HD 4870 X2 2GB
  • ATI Radeon HD 4870 1GB CrossFire
    • 186.4
    • 193.7
    • 197.3
    • 223.9
    • 231.2
    • 236.0
    • 236.5
    • 239.0
    • 241.5
    • 251.1
    • 313.6
100
150
200
250
300
350
Power at socket (W)
  • Power Consumption (W)
Power Consumption (load)
Crysis DX10 at 1,920 x 1,200 0xAA 16xAF, Average Power Usage
    • 317.2
    • 341.9
    • 343.7
    • 352.6
    • 360.6
    • 373.1
    • 433.5
    • 471.5
    • 472.5
    • 494.4
    • 545.6
200
300
400
500
600
Power at socket (W)
Power Consumption (peak)
Crysis DX10 at 1,920 x 1,200 0xAA 16xAF, Peak Power Usage
    • 326.2
    • 353.1
    • 355.9
    • 376.9
    • 384.6
    • 392.4
    • 459.8
    • 497.8
    • 498.9
    • 525.1
    • 579.1
200
300
400
500
600
Power at socket (W)
While the Sapphire ATI Radeon HD 4850 X2's idle power consumption is quite a bit higher than the GeForce GTX 285's, it's not so high that it is a cause for concern - it is only 0.5W more power hungry than our Radeon HD 4870 1GB for example, even despite using a pair of RV770 GPUs compared to the 4870's single RV770.
At load, the 4850 X2 uses around 20W more power than Nvidia's GeForce GTX 285 - that's not as significant as it sounds and only represents a 5.8 percent increase. Overall, we're fairly impressed with what Sapphire has managed to achieve with its dual-GPU behemoth when it comes to energy efficiency. Saying it's energy efficient compared to the GTX 285 is of course a stretch, but that's mainly down to the massive gulf in idle power consumption - had Sapphire managed to somehow lower the card's idle consumption, then we would have been all the more impressed.
