Fallout 3
Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent Fallout series of games following many years out of the limelight. It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more Fallout games in the future.
Despite using the Oblivion engine which is now a few years old, the game looks absolutely stunning. Bethesda has spiced up the graphics a bit since Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC. We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel. This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60FPS cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s abilities.
Nvidia (Zotac) GeForce GTX 285 1GB Fallout 3 Nvidia (Zotac) GeForce GTX 285 1GB Fallout 3
Fallout 3
1,680 x 1,050 4xAA 16xAF, Maximum Detail
  • Nvidia GeForce GTX 280 1GB SLI
  • Nvidia GeForce GTX 295 1,792MB
  • Nvidia GeForce GTX 260-216 896MB SLI
  • ATI Radeon HD 4870 1GB CrossFire
  • ATI Radeon HD 4870 X2 2GB
  • Zotac GeForce GTX 285 1GB AMP!
  • Nvidia GeForce GTX 285 1GB
  • ATI Radeon HD 4870 512MB
    • 83.3
    • 58.0
    • 82.5
    • 58.0
    • 81.6
    • 57.0
    • 80.7
    • 56.0
    • 80.5
    • 49.0
    • 79.1
    • 44.0
    • 77.5
    • 40.0
    • 70.9
    • 37.0
    • 70.9
    • 33.0
    • 64.0
    • 30.0
    • 62.4
    • 32.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
1,680 x 1,050 8xAA 16xAF, Maximum Detail
    • 81.3
    • 48.0
    • 81.2
    • 50.0
    • 80.9
    • 46.0
    • 80.3
    • 49.0
    • 79.4
    • 48.0
    • 69.9
    • 35.0
    • 67.4
    • 32.0
    • 66.9
    • 27.0
    • 59.7
    • 29.0
    • 52.4
    • 23.0
    • 44.7
    • 13.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
1,920 x 1,200 4xAA 16xAF, Maximum Detail
    • 82.7
    • 49.0
    • 81.3
    • 48.0
    • 81.3
    • 45.0
    • 80.3
    • 48.0
    • 79.5
    • 46.0
    • 75.0
    • 39.0
    • 72.8
    • 37.0
    • 64.7
    • 30.0
    • 64.1
    • 32.0
    • 61.5
    • 25.0
    • 55.6
    • 28.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
1,920 x 1,200 8xAA 16xAF, Maximum Detail
    • 80.8
    • 48.0
    • 79.1
    • 41.0
    • 79.1
    • 45.0
    • 78.9
    • 40.0
    • 78.5
    • 43.0
    • 65.1
    • 29.0
    • 62.4
    • 28.0
    • 62.0
    • 24.0
    • 55.6
    • 23.0
    • 48.7
    • 18.0
    • 35.1
    • 6.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
Fallout 3
2,560 x 1,600 0xAA 16xAF, Maximum Detail
    • 82.3
    • 49.0
    • 81.9
    • 48.0
    • 81.7
    • 47.0
    • 80.4
    • 50.0
    • 79.5
    • 45.0
    • 74.9
    • 37.0
    • 72.6
    • 35.0
    • 64.7
    • 32.0
    • 59.7
    • 30.0
    • 59.0
    • 30.0
    • 57.5
    • 24.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
2,560 x 1,600 4xAA 16xAF, Maximum Detail
    • 80.1
    • 43.0
    • 77.8
    • 41.0
    • 77.5
    • 37.0
    • 77.3
    • 32.0
    • 77.0
    • 36.0
    • 59.6
    • 27.0
    • 58.6
    • 26.0
    • 52.0
    • 24.0
    • 51.5
    • 20.0
    • 45.7
    • 19.0
    • 27.6
    • 2.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
Fallout 3
2,560 x 1,600 8xAA 16xAF, Maximum Detail
    • 75.6
    • 25.0
    • 73.6
    • 23.0
    • 70.0
    • 27.0
    • 50.6
    • 18.0
    • 47.7
    • 16.0
    • 47.4
    • 17.0
    • 46.5
    • 15.0
    • 45.1
    • 16.0
    • 39.8
    • 13.0
    • 31.3
    • 8.0
    • 1.5
    • 0.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
The GeForce GTX 285's additional performance means that the Radeon HD 4870 1GB is no longer a problem at high resolutions with high levels of anti-aliasing enabled in Fallout 3 - it's quite simply the fastest single GPU graphics card almost right across the board. The only exception is at 2,560 x 1,600, where the Radeon bests the Nvidia reference clocked GeForce GTX 285 by 1.4 fps on average, although the GeForce still maintains a higher minimum frame rate.
