Far Cry 2 is the latest first person shooter from Ubisoft and it's one of the most hotly-anticipated games of this year. While it continues the Far Cry franchise that Crytek started in 2004, Far Cry 2 is built on its own in-house engine and has no association to anything Crytek has worked on or is working on now.
The game makes use of DirectX 10.1 to improve anti-aliasing performance and quality. The improvements are made by reading the multisampled depth buffer in a single pass - something that was only introduced officially with DirectX 10.1. However, Ubisoft has also made the enhancements available to Nvidia hardware as well through a DirectX 10 extension.
We used the game's built-in benchmarking tool to measure performance - this provided a pretty accurate rundown of how various hardware performs and it shows off a lot of the game's special effects. We set every option to its maximum setting and tested at 1,680 x 1,050, 1,920 x 1,200 and 2,560 x 1,600 with various anti-aliasing settings.
Anisotropic filtering is controlled by the game's quality settings and forcing AF from the driver control panel does not have any affect on visual quality or performance.
Far Cry 2
1,680 x 1,050 0xAA, DirectX 10/10.1, Ultra High Quality
Nvidia GeForce GTX 280 1GB
ATI Radeon HD 4870 X2 2GB
ATI Radeon HD 4870 1GB
Sapphire ATI Radeon HD 4850 X2 2GB
Nvidia GeForce GTX 260+ 896MB
ATI Radeon HD 4870 512MB
ATI Radeon HD 4850 512MB
Nvidia GeForce 9800 GTX+ 512MB
53.0
37.0
51.0
33.0
49.8
37.0
48.7
32.0
48.1
36.0
43.5
31.0
37.9
30.0
33.2
25.0
20
30
40
50
Frames Per Second
Average
Minimum
Far Cry 2
1,680 x 1,050 2xAA, DirectX 10/10.1, Ultra High Quality
55.6
35.0
53.8
34.0
49.3
37.0
45.4
36.0
43.9
34.0
35.3
23.0
33.4
23.0
31.4
24.0
20
30
40
50
60
Frames Per Second
Average
Minimum
Far Cry 2
1,680 x 1,050 4xAA, DirectX 10/10.1, Ultra High Quality
54.7
35.0
51.5
33.0
46.3
36.0
40.7
33.0
40.0
31.0
28.7
19.0
28.1
16.0
25.8
17.0
20
30
40
50
60
Frames Per Second
Average
Minimum
Far Cry 2
1,920 x 1,200 0xAA, DirectX 10/10.1, Ultra High Quality
49.9
32.0
48.5
36.0
48.4
37.0
48.3
32.0
43.0
34.0
38.6
30.0
36.6
29.0
29.9
21.0
20
30
40
50
Frames Per Second
Average
Minimum
Far Cry 2
1,920 x 1,200 2xAA, DirectX 10/10.1, Ultra High Quality
55.2
36.0
52.0
33.0
45.3
35.0
43.2
34.0
40.1
32.0
33.8
19.0
31.5
17.0
24.4
16.0
20
30
40
50
60
Frames Per Second
Average
Minimum
Far Cry 2
1,920 x 1,200 4xAA, DirectX 10/10.1, Ultra High Quality
53.7
34.0
50.1
33.0
41.3
34.0
37.4
30.0
36.2
29.0
22.0
17.0
20.9
15.0
20.8
14.0
20
30
40
50
60
Frames Per Second
Average
Minimum
Far Cry 2
2,560 x 1,600 0xAA, DirectX 10/10.1, Ultra High Quality
42.6
30.0
39.3
29.0
37.8
30.0
35.8
29.0
33.5
26.0
25.0
20.0
21.4
15.0
21.1
15.0
20
30
40
Frames Per Second
Average
Minimum
Far Cry 2
2,560 x 1,600 2xAA, DirectX 10/10.1, Ultra High Quality
46.4
34.0
43.3
33.0
34.6
27.0
30.9
24.0
30.8
24.0
16.7
12.0
14.8
11.0
12.2
7.0
20
30
40
50
Frames Per Second
Average
Minimum
Far Cry 2
2,560 x 1,600 4xAA, DirectX 10/10.1, Ultra High Quality
33.8
25.0
31.8
23.0
31.7
24.0
26.8
21.0
24.2
19.0
12.0
8.0
11.2
7.0
7.5
2.0
10
15
20
25
30
35
Frames Per Second
Average
Minimum
Strangely, both the Sapphire Radeon HD 4850 X2 and ATI Radeon HD 4870 X2 are slower when anti-aliasing is disabled - it's as if they're CPU limited at even the highest resolutions until anti-aliasing is enabled, as performance increases once even 2xAA is turned on. Sapphire's card is faster than the GeForce GTX 280 at every setting with anti-aliasing turned on and since there's enough performance available, you'd be a fool not to enable AA.
Playability is there right up to 2,560 x 1,600 2xAA, which is exactly where the 4870 X2's playability threshold comes as well. The GTX 280 is marginally playable at these settings and 1,920 x 1,200 seems to be the best fit for Nvidia's flagship card.
