What can we say about this game that hasn’t been said already? Crysis was probably the most anticipated game on the PC last year and was released on November 16th 2007.
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 30-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
For our testing, we set all quality details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4x anti-aliasing, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA. By extensively testing using anti-aliasing in very high resolutions, we'll be pushing even the bleeding edge hardware on test to the limit.
Crysis
1280x1024 0xAA 8xAF, DX9, High Detail
ATI Radeon HD 4870 X2
ECS GeForce 9800 GTX+ Hydra SLI
ATI Radeon HD 4850 CrossFire
Nvidia GeForce GTX 280
Nvidia GeForce GTX 260+
ATI Radeon HD 4870 1GB
ATI Radeon HD 4870 512MB
ATI Radeon HD 3870 X2
Nvidia GeForce 9800 GTX+
ATI Radeon HD 4850
Nvidia GeForce 8800 GT
78.6
35.0
73.0
37.0
64.9
28.0
56.0
33.0
49.0
29.0
46.1
25.0
45.9
26.0
45.8
27.0
44.2
21.0
39.0
23.0
36.3
20.0
30.5
18.0
20
30
40
50
60
70
80
Frames Per Second
Average
Minimum
Crysis
1280x1024 2xAA 8xAF, DX9, High Detail
ATI Radeon HD 4850
66.3
31.0
61.2
31.0
53.1
25.0
51.1
31.0
44.2
26.0
41.9
24.0
38.8
23.0
38.1
23.0
33.3
17.0
33.2
19.0
29.3
17.0
26.5
16.0
20
30
40
50
60
70
Frames Per Second
Average
Minimum
Crysis
1280x1024 4xAA 8xAF, DX9, High Detail
ATI Radeon HD 4850
63.4
33.0
55.2
29.0
51.0
24.0
48.3
29.0
41.7
25.0
39.6
23.0
37.7
21.0
36.7
22.0
32.7
17.0
30.2
17.0
28.0
16.0
24.2
14.0
20
30
40
50
60
70
Frames Per Second
Average
Minimum
Crysis
1680x1050 0xAA 8xAF, DX9, High Detail
ATI Radeon HD 4850
58.5
27.0
54.9
30.0
47.1
21.0
44.6
29.0
39.1
25.0
37.0
22.0
36.6
22.0
36.5
23.0
31.9
16.0
31.3
19.0
29.0
17.0
24.6
15.0
20
30
40
50
60
Frames Per Second
Average
Minimum
Crysis
1680x1050 4xAA 8xAF, DX9, High Detail
ATI Radeon HD 4850
46.8
23.0
38.4
25.0
35.1
18.0
33.2
21.0
31.5
20.0
30.1
18.0
30.0
18.0
28.0
17.0
23.5
10.0
21.9
13.0
19.9
11.0
16.6
9.0
20
30
40
50
Frames Per Second
Average
Minimum
Crysis
1920x1200 0xAA 8xAF, DX9, High Detail
ATI Radeon HD 4850
46.8
21.0
43.1
23.0
36.0
13.0
35.9
23.0
31.4
20.0
29.6
17.0
29.3
17.0
29.2
18.0
25.6
13.0
25.1
15.0
22.7
13.0
19.9
11.0
20
30
40
50
Frames Per Second
Average
Minimum
Crysis
1920x1200 2xAA 8xAF, DX9, High Detail
ATI Radeon HD 4850
38.9
18.0
32.6
20.0
30.6
14.0
29.7
14.0
28.1
18.0
26.6
17.0
24.7
15.0
23.7
15.0
18.9
10.0
18.1
11.0
17.5
6.0
15.5
9.0
20
30
40
Frames Per Second
Average
Minimum
Crysis
2560x1600 0xAA 8xAF, DX9, High Detail
ATI Radeon HD 4850
27.1
9.0
22.5
12.0
21.4
8.0
21.1
7.0
19.5
10.0
18.1
9.0
17.6
9.0
17.2
8.0
14.6
5.0
14.2
7.0
13.5
6.0
11.0
4.0
10
15
20
25
30
Frames Per Second
Average
Minimum
Switching to DirectX 9.0 brings a huge change to the results, with the pair of ECS 9800 GTX+ turning in some marvellous results at low resolutions under all anti-aliasing levels, and it's not until 4xAA at 1,680 x 1,050 that we see the usual front runners replace the SLI set up.
The CrossFired 4850s also perform superbly, offering performance extremely comparable to the Nvidia GeForce GTX 280 at resolutions less than 2,560 x 1,600, and outpacing the SLIed 9800 GTX+s when higher AA settings are applied at mid range and higher resolutions.
