Inno3D GeForce 7900 GS iChiLL ACS6
Call of Duty 2:
Publisher: Activision
We used the full version of Call of Duty 2, patched to version 1.2. The game makes use of some awesome effects and is generally very graphically intense and immersive. That's helped by the tremendous smoke effect that Infinity Ward have created - it's better than anything we've ever seen before. There are also real time shadows and a subtle HDR lighting effect too.
The gameplay is not as linear as the first version of Call of Duty, and Infinity Ward has ditched the rather old Quake 3 engine in favour of creating its own proprietary graphics engine to render the effects. There is something about the game that makes it very intense and you often find yourself having to take a break from the action because you're too overwhelmed by its immersiveness and intensity.
We used a custom timedemo that covers both indoor and outdoor performance in the title across one of the most intensive portions of the game. The Optimise for SLI option was disabled for single GPU configurations as it causes some texture corruption if there is only one GPU present. It was enabled for dual-GPU configurations and all other options were set to their maximum values.
Inno3D GeForce 7900 GS iChiLL ACS6 Call Of Duty 2 Inno3D GeForce 7900 GS iChiLL ACS6 Call Of Duty 2
The iChiLL delivered good frame rates in Call of Duty 2 at 1280x1024 with 4xAA enabled, and you'll also be able to squeeze some reasonable frame rates out of the card at 1600x1200 in this game too. It managed to hold more consistent performance than Connect3D's Radeon X1950 XT 256MB, too.
