Nanoxia Deep Silence 4 Review
April 18, 2014 | 09:15
Tags: #air-cooling #deep-silence #micro-atx #micro-atx-case #quiet-case #quiet-computing #silent-computing
Companies: #nanoxia
Cooling Performance
Our micro-ATX test kit contains an Intel Core i7-875K CPU, which has been overclocked from 2.93GHz to 3.4GHz using a vcore of 1.175V and a CPU PLL of 1.86V. This is an admittedly modest overclock, but as some cases that we have trialled previously made the CPU run at a Delta T of nearly 60°C, it's reasonable for a micro-ATX case.
The CPU is cooled by a Gelid Tranquillo with a Noctua NF-S12B ULN 120mm fan. We run this at a consistent 12V speed, but it is a low-airflow fan, so it will highlight cases with poor cooling for the CPU. We also lock the fan speed on the graphics card to 30 percent in order to prevent the automatic speed control from interfering with the results, making them inconsistent.
We load the system using the Small FFTs CPU stress test in Prime95 and the Unigine Heaven DirectX 11 GPU benchmark. After at least 15 minutes, once temperatures have plateaued, we record the temperature of the hottest CPU core using Core Temp and of the GPU using GPU-Z. Having recorded the ambient temperature in front of the main air intake of each case, we're then able to calculate the delta T - the difference between the ambient temperature of our lab and the temperature of the hardware.
  • CPU: Intel Core i7-875K CPU overclocked to 3.4GHz (22 x 155MHz)
  • Graphics Card: Sapphire Radeon HD 5770 1GB
  • Motherboard: Gigabyte GA-H55M-UD2R
  • RAM: 2GB PNY 1,600MHz DDR3
  • Storage: Corsair Force GT 60GB SSD
  • Heatsink: Gelid Tranquillo with a Noctua NF-S12B ULN fan
  • Power Supply: Seasonic M12D SS-850EM
Case performance - CPU Delta T
Arranged by CPU Delta T
  • SilverStone Sugo SG10 (max speed)
  • SilverStone Sugo SG10 (min speed)
  • Fractal Design Arc Mini R2 (max speed; no HDD cage)
  • Corsair Obsidian 350D
  • Fractal Design Arc Mini R2 (min speed)
  • Nanoxia Deep Silence 4 (max speed; no HDD cage)
  • Nanoxia Deep Silence 4 (max speed)
  • Aerocool Dead Silence Cube (mesh roof)
  • Aerocool Dead Silence Cube (default roof)
  • Nanoxia Deep Silence 4 (min speed)
    • 40
    • 46
    • 42
    • 47
    • 44
    • 48
    • 45
    • 47
    • 51
    • 55
    • 53
    • 46
    • 53
    • 47
    • 56
    • 52
    • 60
    • 58
    • 62
    • 59
20
30
40
50
60
°C, lower is better
  • CPU Delta T
  • GPU Delta T
Case performance - GPU Delta T
Arranged by GPU Delta T
    • 40
    • 46
    • 53
    • 46
    • 42
    • 47
    • 53
    • 47
    • 45
    • 47
    • 44
    • 48
    • 56
    • 52
    • 51
    • 55
    • 60
    • 58
    • 62
    • 59
20
30
40
50
60
°C, lower is better
  • CPU Delta T
  • GPU Delta T
Read our performance analysis on the next page.
