Akasa Galileo Cooling Performance
Cooling Performance
Our test kit is fairly indicative of the kind of PC that most people will be opting for and we also carried out tests in an enclosed TV cabinet, in the open and while streaming HD content on Netflix to give you some idea as to the impact these situations will have given the case is passively-cooled.
Otherwise we used Prime95 to push our CPU to the max to see how the cooling system fared in a worst-case scenario, recording the CPU temperature using Core Temp. We tested using a 35W Intel Pentium G2100T CPU and Intel BOXDQ77KB slim motherboard.
While Akasa specifies a TDP limit of 35W we threw in the Core i3-2100 65W CPU we used recently to see what happened, especially as common tasks like Netflix don't require 100 per cent CPU usage and 65W models are usually much cheaper too. All results in the graph are using the Core i3-2100 unless stated otherwise.
Our test kit comprised the following:
  • Intel Core i3-2100 (65W TDP)
  • Intel Pentium G2100T (35W TDP)
  • IIntel BOXDQ77KB mini-ITX motherboard
  • OCZ Vertex SSD
Case performance - CPU Delta T
Arranged by CPU Delta T
  • Akasa Galileo (enclosed)
  • Akasa Euler (enclosed)
  • Akasa Euler (open)
  • Akasa Galileo (open)
  • Streacom ST-FC5S EVO WS (enclosed)
  • Streacom ST-FC5S EVO WS (open)
  • Akasa Galileo (Intel Pentium G2100T 35W - enclosed)
  • Akasa Galileo (HD Video Playback, enclosed)
  • Akasa Euler (Intel Pentium G2100T 35W - enclosed)
  • Akasa Galileo (Intel Pentium G2100T 35W - open)
  • Akasa Euler (HD Video Playback, enclosed)
  • Akasa Euler (Intel Pentium G2100T 35W - open)
  • Akasa Galileo (Intel Pentium G2100T 35W - HD Video Playback, enclosed)
  • Streacom ST-FC5S EVO WS (HD Video Playback, enclosed)
  • Akasa Euler (Intel Pentium G2100T 35W - HD Video Playback, enclosed)
  • 63
  • 61
  • 58
  • 57
  • 52
  • 44
  • 40
  • 38
  • 36
  • 32
  • 29
  • 28
  • 25
  • 20
  • 18
20
30
40
50
60
70
°C, lower is better
