SilverStone Fortress FT03 Review
Written by Paul Goodhead
February 15, 2011 | 07:57
Tags: #air-cooling #aluminium #best #case #coolest #fans #fortress #ft02 #ft03 #m-atx #micro-atx #midi-case #quiet #recommended #tower-case
Companies: #mesh #silverstone
SilverStone FT03 Cooling Performance
Our micro-ATX test kit comprises an ATI Radeon HD 5870 2GB Eyefinity 6 graphics card and an Intel Core i7-875K CPU, which has been overclocked from 2.93GHz to 3.4GHz using a vcore of 1.175V and a CPU PLL of 1.86V. This is an admittedly modest overclock but as some cases that we trialled made the CPU run at a Delta T of 54°C, it's reasonable for a micro-ATX case.
The CPU is cooled by a Gelid Tranquillo with a Noctua NF-S12B ULN 120mm fan. The NF-S12B ULN is a low-airflow fan, so it will highlight cases with poor cooling for the CPU. We also locked the fan speed on the graphics card to 30 per cent in order to prevent the automatic speed control from interfering with the results, making them inconsistent.
We recorded the temperature of the CPU using RealTemp, noting the temperature of the hottest core, and used GPU-Z to log the temperature of the graphics card. Having recorded the ambient temperature in front of the main air intake of each case, we were then able to calculate the delta T - the difference between the ambient temperature of our lab and the temperature of the hardware.
To load the system, we used a combination of the Canyon Flight benchmark in 3DMark06 and the smallfft test in Prime 95. We looped each test for a minimum of 30 minutes, or until the temperatures plateaued, and recorded the highest temperature in the log files.
  • CPU: Intel Core i7-875K CPU overclocked to 3.4GHz
  • Graphics Card: ATI Radeon HD 5870 2GB Eyefinity 6
  • Motherboard: Gigabyte GA-H55M-UD2R
  • RAM: 2 x 2GB OCZ 1,866MHz DDR3
  • Hard Drive: 1 x 160GB Seagate Barracuda 7200.9
  • Heatsink: Gelid Tranquillo with a Noctua NF-S12B ULN fan
  • Power Supply: Seasonic M12D SS-850EM
Case performance - CPU Delta T
Arranged by CPU Delta T
  • Antec P180 Mini (high speed)
  • SilverStone Fortress FT03
  • Antec P180 Mini (low speed)
    • 46
    • 45
    • 47
    • 43
    • 54
    • 45
20
30
40
50
60
°C, lower is better
  • CPU Delta T
  • GPU Delta T
Case performance - GPU Delta T
Arranged by GPU Delta T
    • 47
    • 43
    • 46
    • 45
    • 54
    • 45
20
30
40
50
60
°C, lower is better
  • CPU Delta T
  • GPU Delta T
