We followed our standard case testing methodology, as detailed in our previous heatsink and case testing article, and fitted the usual set of hardware into the Lian Li PC-9, doing our best to hide and tidy cables to ensure as few airflow restrictions as possible, which in this case proved very difficult indeed. Here's a reminder of the hardware we use.
CPU: Lapped Intel Pentium XE 955 (dual-core, 3.46GHz) Graphics Card: Sapphire Radeon HD 3850 Ultimate passive cooled Motherboard: MSI P6N SLI Platinum RAM: 2x 512MB Corsair XMS2-667 Hard Drive: 1x 250GB Western Digital WD2500 7,200RPM Heatsink: Asus Silent Square Pro Power Supply: Xilence XP700 700W PSU
While this isn't representative of current ultra high end hardware, the equipment we use is specifically selected to kick out the maximum amount of heat inside the case, with a passively cooled graphics card and 130W TDP processor at its core to really heat things up and push the case's ability to cope with toasty components to the limit.
In our experience, the CPU stress test is a good test to indicate a case's ability to exhaust hot air and the GPU stress test is a better indicator of a case's intake ability as the GPU is generally further from the exhaust fan and so its operating temperatures rely more on case airflow than exhaust.
We were little concerned about the Lian Li PC-9's ability to cope with our test system's high thermal output hardware, especially considering the very strange cooling layout. Let's see how it got on.
