Silverstone Fortress FT01
Testing Time
We followed our standard case testing methodology, as detailed in our previous heatsink and case testing article, and fitted the usual set of hardware into the Silverstone FT01, doing our best to hide and tidy cables to ensure as few airflow restrictions as possible. Here's a reminder of the hardware we use.
CPU: Lapped Intel Pentium XE 955 (dual-core, 3.46GHz)
Graphics Card: Sapphire Radeon HD 3850 Ultimate passive cooled
Motherboard: MSI P6N SLI Platinum
RAM: 2x 512MB Corsair XMS2-667
Hard Drive: 1x 250GB Western Digital WD2500 7,200RPM
Heatsink: Asus Silent Square Pro
Power Supply: Xilence XP700 700W PSU
While this isn't representative of current ultra high end hardware, the equipment we use is specifically selected to kick out the maximum of heat inside the case, with a passively cooled graphics card and 130W TDP processor at its core to really heat things up and push the case's ability to cope with toasty components to the limit. If the Hiper Osiris can cope with this set up, it should comfortably handle anything.
We were a little concerned about the obstruction to airflow posed by the large hard drive mounting cages, but were still interested to see if the positive air pressure cooling of the FT01 could compete with the top performers in our thermal testing.
Silverstone FT01 Testing and Results
Case performance - Idle
Arranged by CPU Delta T
  • Cooler Maser HAF 932
  • Akasa Omega - all fans
  • SilverStone FT01
  • Zalman GS1000
  • Hiper Osiris
  • Akasa Omega - stock fans
  • Lancool K7 Metal Boned
  • Lian Li Tyr PC-X2000 - high fan
  • Akasa Mirage-62
    • 20
    • 21
    • 28
    • 33
    • 8
    • 24
    • 25
    • 33
    • 37
    • 9
    • 21
    • 22
    • 30
    • 41
    • 9
    • 22
    • 24
    • 32
    • 37
    • 10
    • 22
    • 22
    • 31
    • 37
    • 11
    • 24
    • 25
    • 35
    • 45
    • 11
    • 22
    • 24
    • 34
    • 40
    • 12
    • 22
    • 24
    • 34
    • 38
    • 12
    • 21
    • 24
    • 34
    • 39
    • 13
20
30
40
50
°C
  • Ambient
  • Case
  • CPU
  • GPU
  • Load Delta T (CPU)
Case performance - CPU stress test
  • SilverStone FT01
  • Cooler Master HAF 932
  • Hiper Osiris
  • Zalman GS1000
  • Akasa Mirage-62
    • 21
    • 22
    • 41
    • 42
    • 20
    • 21
    • 22
    • 43
    • 35
    • 22
    • 20
    • 22
    • 43
    • 39
    • 23
    • 22
    • 24
    • 45
    • 37
    • 23
    • 22
    • 25
    • 46
    • 37
    • 24
    • 23
    • 25
    • 47
    • 38
    • 24
    • 24
    • 25
    • 50
    • 45
    • 26
    • 22
    • 24
    • 49
    • 41
    • 27
    • 21
    • 24
    • 49
    • 39
    • 28
20
30
40
50
°C
  • Idle
  • Case
  • CPU
  • GPU
  • CPU Delta T (load)
Case performance - GPU stress test
Arranged by GPU Delta T
  • Akasa Omega - All Fans
  • Zalman GS1000
  • Hiper Osiris
  • SilverStone FT01
  • Akasa Mirage-62
    • 22
    • 25
    • 43
    • 54
    • 32
    • 23
    • 25
    • 43
    • 55
    • 32
    • 21
    • 23
    • 39
    • 53
    • 32
    • 22
    • 26
    • 42
    • 57
    • 35
    • 20
    • 23
    • 42
    • 62
    • 42
    • 24
    • 25
    • 44
    • 69
    • 45
    • 22
    • 24
    • 39
    • 68
    • 46
    • 22
    • 23
    • 42
    • 70
    • 48
    • 21
    • 24
    • 38
    • 71
    • 50
20
30
40
50
60
70
°C
  • Ambient
  • Case
  • CPU
  • GPU
  • GPU Delta T
