We followed our standard case testing methodology, as detailed in our previous heatsink and case testing article, and fitted the usual set of hardware into the GS1000, doing our best to hide and tidy cables to ensure as few airflow restrictions as possible. Here's a reminder of the hardware we use.
CPU: Lapped Intel Pentium XE 955 (dual-core, 3.46GHz) Graphics Card: Sapphire Radeon HD 3850 Ultimate passive cooled Motherboard: MSI P6N SLI Platinum RAM: 2x 512MB Corsair XMS2-667 Hard Drive: 1x 250GB Western Digital WD2500 7,200RPM Heatsink: Asus Silent Square Pro Power Supply: Xilence XP700 700W PSU
With the two 120mm exhaust so close to the CPU heatsink and the lack of intake fans, we were expecting some interesting results.
Delta T is the difference in temperature between CPU or GPU and the ambient temperature. A lower Delta T is better as it shows the case or cooling solution is performing closer to the surrounding temperature.
