Externals
Antec Nine Hundred Externals Antec Nine Hundred Externals
The side panel window is clear perspex and is presented in an aggressive arrow shape. The rear of the window is also covered in mesh and has a mount for a 120mm fan, should you wish to install one blowing directly onto the graphics card.
Both side panels are held on the rear by black thumbscrews, which are just a little too small to be comfortable. The side panels have the windows riveted in place, which means you're not going to be easily pulling the window out to etch.
Here you can see one of the big design differences that sets the Nine Hundred apart from other cases. The PSU is mounted at the bottom of the case, with the ATX motherboard being shifted up above. There's a 120mm fan over the I/O panel.
Shopping
