Cooler Master's Praetorian 731
No surprises inside
Coolermaster's Praetorian 731 Insides
Cooler Master introduced me to the joys of a well implemented motherboard tray and thankfully it's still present in the Praetorian. Thumbscrews hold it in place and with them removed it slides out of the back of the case taking your expansion cards with it.
It now houses two fairly low power 80mm fans (blue LED lit) but they're not as quiet as I'd like.
A pair of intake fans at the front of the case complete its cooling solution.
Coolermaster's Praetorian 731 Insides Coolermaster's Praetorian 731 Insides
Elsewhere inside the case things are as you'd expect.
A large bag of screws is supplied with a basic instruction manual and the spare 80mm fan we talked about earlier.
