Intel Skylake: Intel Z170 Chipset and Core i7-6700K Review
Written by Antony Leather
August 5, 2015 | 12:58
Tags: #6600k #lga1151 #skylake #z170
Companies: #intel
PCMark 8 Video Editing
Video Editing v2 Part 2 (Creative 3.0 test suite)
This workload uses FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
PCMark 8 4K Video Editing
Part 2 test
  • Intel Core i7-6700K (4GHz/4.8GHz)
  • Intel Core i7-4790K (4GHz/4.8GHz)
  • Intel Core i7-4770K (3.5GHz/4.8GHz)
  • Intel Core i7-5820K (3.3GHz/4.3GHz)
    • 112
    • 98
    • 117
    • 103
    • 126
    • 103
    • 134
    • 113
50
75
100
125
150
Seconds, lower is better
  • Stock
  • Overclocked
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Load image matrix + adjusting times
  • Core i7-6700K (4GHz/4.8GHz)
  • Core i7-4770K (3.5GHz/4.8GHz)
    • 31
    • 30
    • 33
    • 28
    • 34
    • 32
    • 38
    • 32
20
30
40
  • Stock
  • Overclocked
