Intel Haswell-E; Intel Core i7-5960X Review, X99 Chipset and DDR4
Written by Antony Leather
August 29, 2014 | 16:58
Tags: #haswell-e #haswell-e-review #intel-core-i7-5820k-review #intel-core-i7-5930k-review #intel-core-i7-5960x-review #lga2011-v3 #x99 #x99-review
Companies: #intel
Multi-tasking with 7-Zip and mplayer
Websites: www.7-zip.org and www.mplayerhq.hu
Multi-tasking is a phrase with which we're all familiar, as most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back a HD movie file using mplayer, making it a demanding test for any PC.
Multi-tasking
Applications: mplayer and 7-Zip
  • Intel Core i7-4960X (3.6GHz/4.4GHz)
  • Intel Core i7-4770K (3.5GHz/4.7GHz)
  • Intel Core i7-3960X Extreme Edition (3.3GHz/4.7GHz)
  • Intel Core i7-4790K (4GHz/4.8GHz)
  • Intel Core i7-5960X (3GHz/4.45GHz)
  • Intel Core i7-4930K (3.4GHz/4.5GHz)
  • Intel Core i7-3930K (3.2GHz/4.7GHz)
  • Intel Core i3-4130 (3.4GHz)
  • AMD FX-8350 (4GHz/4.8GHz)
    • 1707
    • 1815
    • 1666
    • 1782
    • 1645
    • 1984
    • 1642
    • 1675
    • 1634
    • 1841
    • 1564
    • 1790
    • 1540
    • 1956
    • 1320
    • 0
    • 1260
    • 1401
1000
1500
2000
Score, higher is better
  • Stock Speed
  • Overclocked
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests. A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Overall Score
Applications: Gimp, Handbrake, mplayer, 7-Zip
  • Core i7-4770K (3.5GHz/4.7GHz)
  • Intel Core i5-4670K (3.4GHz/4.6GHz)
    • 2654
    • 2884
    • 2515
    • 3071
    • 2478
    • 2966
    • 2436
    • 2860
    • 2258
    • 2730
    • 2252
    • 2962
    • 1788
    • 0
    • 1660
    • 1914
1000
1500
2000
2500
3000
  • Stock Speed
  • Overclocked
