The Elder Scrolls V: Skyrim
Publisher: Bethesda
Asus Maximus VII Gene Review Asus Maximus VII Gene Review - Gaming and Audio Performance
From our The Elder Scrolls V: Skyrim review:
'It’s like watching Star Wars and genuinely thinking, ‘what about those poor Death Star construction workers?’ You’re missing the point: Skyrim is a huge and engaging world to explore and it treats you with great moments, from your first dragon encounter to finally being able to craft dwarven armour.'
We've updated our Skyrim benchmark to include the official high resolution texture pack, available as a free DLC. We set the game to its 'Ultra' setting and record a sixty second manual play through just outside the town of Whiterun during a thunderstorm. We use a section where we are able to run forward in a straight line for a minute without being attacked so the benchmark remains consistent, and use the third person camera view.
Many modern games make little use of the CPU, instead ploughing resources into the GPU, making the CPU’s impact on high-resolution performance difficult to test. As such, we’ve drafted in the Elder Scrolls: Skyrim, one of the easier games in our 3D benchmark suite, as well as a GeForce GTX 780 3GB to remove as many of the graphical limitations as possible. We’ve still tested at a meaningful resolution however, and with ultra-detail and high-resolution textures (although no AA).
The Elder Scrolls: Skyrim
1,920 x 1,080, Ultra Settings, 0x AA, 16x AF
  • Asus Maximus VII Hero (4.8GHz)
  • Gigabyte GA-Z97X-SLI (4.7GHz)
  • Asus Maximus VII Gene (4.8GHz)
  • MSI Z97 MPower (4.8GHz)
  • MSI Z97M Gaming (4.8GHz)
  • Asus Maximus VII Ranger (4.8GHz)
  • ASRock Fatal1ty Z97 Killer (4.8GHz)
  • MSI Gaming 7 (4.8GHz)
  • ASRock Fatal1ty Z97 Killer (stock speed)
  • MSI Z97 MPower (stock speed)
  • Asus Maximus VII Gene (stock speed)
  • MSI Z97M Gaming (stock speed)
  • MSI Gaming 7 (stock speed)
  • Gigabyte GA-Z97X-SLI (stock speed)
  • Asus Maximus VII Hero (stock speed)
  • Asus Maximus VII Ranger (stock speed)
    • 114
    • 171
    • 114
    • 171
    • 114
    • 170
    • 114
    • 170
    • 112
    • 170
    • 112
    • 169
    • 107
    • 172
    • 105
    • 171
    • 98
    • 160
    • 97
    • 159
    • 97
    • 153
    • 96
    • 155
    • 96
    • 155
    • 96
    • 154
    • 96
    • 153
    • 96
    • 152
50
75
100
125
150
175
frames per second, higher is better
  • Minimum
  • Average
Total War: Shogun 2
Publisher:Sega
Total War games have been making grown PCs cry ever since the original Shogun was released in 2000. The many units, model animations, AI routines and the usual physics and object collision make Shogun 2 as hard a task to run for the CPU as the graphics card.
We use the built-in CPU test, launched by right-clicking on the game in your Steam library. This stages a scripted battle, where we watch the action at a reasonably zoomed-in level. We leave the detail settings at default and record the action for 60 seconds using FRAPS.
Shogun 2: Total War CPU Test
1,920 x 1,080, default settings, no AA, no AF
  • Asus Maximus VI Hero (Z87) (4.7GHz)
  • Asus Maximus VI Hero (Z87) (stock speed)
    • 36
    • 43
    • 36
    • 43
    • 35
    • 43
    • 35
    • 42
    • 35
    • 42
    • 35
    • 42
    • 35
    • 42
    • 35
    • 41
    • 34
    • 42
    • 30
    • 36
    • 30
    • 36
    • 30
    • 36
    • 30
    • 36
    • 30
    • 36
    • 30
    • 35
    • 30
    • 35
    • 29
    • 35
    • 28
    • 36
20
30
40
  • Minimum
  • Average
Rightmark Audio Analyzer
Publisher:Rightmark
We've recently started testing motherboards using RightMark Audio Analyzer. We use the Playback/Recording test, first adjusting levels so they're within the benchmark parameters and then using 24-bit 192KHz tracks, we connect the line-in to the speaker/line-out jack using a standard 3.5mm audio cable.
We're still tweaking this benchmark and cross-checking our results, so please take these numbers with a pinch of salt for now. However, following feedback we felt it important to include some results given that on-board audio is a hotly fought-over area with motherboards at the moment, and none more so than Asus' Gene and Impact boards. For comparison we've used an Asus P8Z77-I Deluxe, which features standard on-board Realtek ALC898 8-Channel High Definition Audio.
Asus Maximus VII Gene Review Asus Maximus VII Gene Review - Gaming and Audio Performance Asus Maximus VII Gene Review Asus Maximus VII Gene Review - Gaming and Audio Performance
Above left - Standard on-board audio. Above right - Asus Maximus VII Gene
Noise Level - lower is better (note these figures are negative)
Dynamic range - higher is better
THD - lower is better
ID+N - lower is better
Stereo Crosstalk - lower is better
ID+N (SF) - lower is better
