Raijintek Morpheus GPU Cooler Review
Written by Antony Leather
May 7, 2014 | 10:05
Tags: #gpu-cooler #graphics-card-cooler #overclocking
Companies: #raijintek
Cooling Performance
We compared the Raijintek Morpheus to the stock cooler of our test GPU, a Radeon R9 290, and also to a custom water-cooling kit using a 60mm-thick dual 120mm-fan radiator, Laing D5 pump and Aqua Computer Kryographics Hawaii Radeon R9 290X full cover waterblock, which is compatible with both the R9 290 and R9 290X.
Testing was undertaken on an open test bench using two Corsair SP120 fans for both the radiator and Morpheus heatsink with results obtained with the fans at 12V and 5V using a fan controller.
Raijintek Morpheus GPU Cooler Review Raijintek Morpheus GPU Cooler Review - Cooling Performance
Heat (load)
Unigine Heaven Benchmark (1,920 x 1,200, Ultra settings, 8xAA
  • Water cooling (12V)
  • Water cooling (5V)
  • Raijintek Morpheus (12V)
  • Raijintek Morpheus (5V)
  • AMD R9 290X 4GB stock cooler
  • 21
  • 22
  • 33
  • 49
  • 72
20
30
40
50
60
70
80
Delta T in °C
