AMD Athlon 5350 (Kabini) Review
Written by Antony Leather
April 24, 2014 | 09:28
Tags: #best-cheap-cpu #cheap-gaming-pc #cheap-pc #htpc #kabini
Companies: #amd
Media Benchmarks
Download from: bit-tech.net
We've developed our own suite of benchmarks using real-world and open-source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake, and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while an HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a machine scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Multi-tasking with 7-Zip and mplayer
Websites: www.7-zip.org and www.mplayerhq.hu
Multi-tasking is a phrase with which we're all familiar, as most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back an HD movie file using mplayer, making it a demanding test for any PC.
Multi-tasking
Applications: mplayer, 7-Zip
  • Intel NUC DC53427RKE (Core i5-3427U 2.5GHz)
  • AMD A8-6500T (2.1GHz)
  • AMD A8-7600 (3.1GHz) (45W TDP)
  • Intel NUC D33217CK (Core i3-3217U 1.8GHz)
  • AMD Athlon 5350 (2.05GHz)
  • Intel Celeron 847 (1.1GHz)
  • AMD E-350
  • 989
  • 924
  • 853
  • 782
  • 486
  • 416
  • 258
500
750
1000
Points (higher is better)
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests. A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a machine scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Overall Score
Applications: Gimp, Handbrake, mplayer, 7-Zip
  • AMD E-350
  • 1247
  • 1244
  • 1001
  • 909
  • 680
  • 513
  • 361
500
750
1000
1250
