Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under scrutiny is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 2.5 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 1,920 x 1,080. We also check that 4x AA and 4x AF are enabled and that tessellation is set to Standard. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
        Nvidia GeForce GTX 660 2GB
        AMD Radeon HD 7870 2GB
        AMD Radeon HD 7970 3GB GHz Edition
        Nvidia GeForce GTX 670 2GB
        Nvidia GeForce GTX 680 2GB
        AMD Radeon HD 7950 3GB
        Zotac GeForce GTX 660 Ti 2GB amp! Editon
        AMD Radeon HD 7950 3GB with Boost
        Nvidia GeForce GTX 560 Ti 1GB
        AMD Radeon HD 6950 1GB
         AMD Radeon HD 6970 2GB
        Nvidia GeForce GTX 690 4GB
        Nvidia GeForce GTX 570 1280MB
            82
            87
            87
            88
            89
            89
            90
            90
            92
            92
            94
            95
            96
            102
    System Power consumption in Watts
        Nvidia GeForce GTX 690 2GB
            188
            202
            210
            222
            227
            230
            246
            253
            253
            256
            257
            293
            315
            373
Thermal Performance
            6
            9
            10
            11
            11
            11
            11
            14
            15
            16
          8
          10.5
          13
          15.5
          18
    Delta T in °C
        Palit GeForce GTX 680 2GB JetStream
        AMD Radeon HD 7970 3GB GHZ Editon
            40
            41
            43
            50
            53
            54
            54
            54
            55
            57
            63
    Delta T in °C
*as there's no stock model of the HD 7850 2GB, it is not included in these graphs
Read our
performance analysis.
