This is where it gets tough, as 1,920 x 1,080 is not only a demanding resolution, but it's also the most popular among PC gamers. In fact, according to the Steam Hardware Survey, over 20 per cent of users are gaming on 1080p screens.
Battlefield 3
1,920 x 1,080, DirectX 11, Ultra Detail Preset
GeForce GTX 590 3GB
AMD Radeon HD 6990 4GB
GeForce GTX 580 1.5GB
GeForce GTX 570 1.3GB
AMD Radeon HD 6970 2GB
GeForce GTX 560 Ti 1GB
AMD Radeon HD 6950 2GB
AMD Radeon HD 6950 1GB
GeForce GTX 560 1GB
AMD Radeon HD 5870 1GB
AMD Radeon HD 6870 1GB
GeForce GTX 460 1GB
AMD Radeon HD 5850 1GB
AMD Radeon HD 6850 1GB
AMD Radeon HD 5770 1GB
GeForce GTX 550 Ti 1GB
82
66
78
61
56
46
49
40
44
34
41
33
39
31
39
31
38
31
37
31
34
26
31
26
31
24
27
21
21
17
24
17
20
30
40
50
60
70
80
90
Frames per Second
Average
Minimum
It looks as though DICE's claims weren't wrong; with the Ultra preset and its 4x anti-aliasing, even the fastest single-GPU cards are unable to produce a minimum frame rate above 46fps, let alone 60fps. The AMD cards seem to be particularly badly affected by the application of 4x AA, with the HD 6970 2GB managing a minimum frame rate of just 34fps; only 1fps more than the much cheaper GTX 560 Ti 1GB.
Further down the order even potent cards from last year such as the GTX 460 1GB struggle, just surpassing the minimum playable frame rate of 25fps.
Battlefield 3
1,920 x 1,080, DirectX 11, High Detail Preset
GeForce GTX 590 3GB
GeForce GTX 560 1GB
GeForce GTX 460 1GB
124
104
100
78
69
56
68
54
61
50
60
48
60
48
57
47
54
44
49
41
51
39
49
38
41
34
41
32
32
26
32
26
50
75
100
125
Frames per Second
Average
Minimum
Switching from the Ultra preset to High drops the 4x AA, and while the image quality is reduced, the performance is much improved, especially for AMD cards. Every card manages a minimum frame rate of above 25fps, with every card from the GTX 560 Ti 1GB managing a passable minimum frame rate of 44fps.
Battlefield 3
1,920 x 1,080, DirectX 11, Medium Detail Preset
GeForce GTX 590 3GB
GeForce GTX 560 1GB
GeForce GTX 460 1GB
149
127
124
101
87
72
80
66
78
65
72
59
72
59
71
59
68
55
62
51
63
49
59
49
52
42
51
40
41
33
40
32
50
75
100
125
150
Frames per Second
Average
Minimum
The drop to the Medium preset disables much more of BF3's graphical finery, including motion blur and most of the anisotropic filtering. It also switches from HBAO to SSAO, and drops the anti-aliasing post processing to medium, as well as dropping all the detail settings.
The result is noticeably reduced image quality, particularly around edges, but also substantially improved performance. Even at 1080P, we see cards from the GTX 560 Ti 1GB upwards deliver minimum frame rates of at least 55fps, and even low end cards are able to top 30fps.
Battlefield 3
1,920 x 1,080, DirectX 11, Low Detail Preset
GeForce GTX 590 3GB
GeForce GTX 560 1GB
GeForce GTX 460 1GB
166
135
138
111
99
82
90
73
88
73
82
68
82
68
80
64
78
64
73
63
70
55
67
54
60
49
57
45
48
39
45
36
50
75
100
125
150
175
Frames per Second
Average
Minimum
At the lowest settings, all anti-aliasing, ambient-occlusion and motion blur is disabled, in addition to the low detail presets and a drop to just 2x anisotropic filtering. However, most cards now manage a minimum frame rate of at least 60fps, even at 1080P.
