Arma II: Operation Arrowhead
Publisher: IDEA Games
From our
Operation Arrowhead Review:
Operation Arrowhead is still a massive challenge for any PC to play smoothly, so you should forget about running it on maximum settings. Bohemia Interactive claims to have optimised things for Arrowhead, but we didn’t find that it ran any faster than Arma II. This is a great shame, as when maxed out, Operation Arrowhead’s guerrilla-infested mountains are simply breathtaking to behold.
Operation Arrowhead doesn’t fundamentally change the gameplay of Arma II, so it’s still a very unforgiving mil-sim. If you’re expecting to run and gun and live then forget it, in a mil-sim such as Operation Arrowhead you have to think like a soldier to survive.'
We test this hugely demanding game at its most challenging settings, with all the detail options set to Very High and High anti-aliasing enabled. For the benchmark itself, we use a 60-second FRAPs run performed within our own custom timedemo. As the benchmark is variable due to AI inconsistencies, tests are performed three times and the average result is used.
*Arma II has recently been updated to version 1.59, and we're in the process of re-testing cards using this new version. This is why all the cards aren't listed in the graphs below*
        Nvidia GeForce GTX 590 3GB
        AMD Radeon HD 6990 4GB (overclocked)
        AMD Radeon HD 6990 4GB (stock)
        PNY XLR8 Liquid Cooled GTX 580 OC 1.5GB
        Asus Matrix GTX580 Platinum
        Nvidia GeForce GTX 580 1.5GB
        Nvidia GeForce GTX 570 1.3GB
        AMD Radeon HD 6970 2GB
        Gainward GeForce GTX 560 Ti Golden Sample
        Nvidia GeForce GTX 560 Ti 1GB
        KFA2 MDT X5 GTX 560 Ti 1GB
        Zotac GeForce GTX 560 1GB AMP!
        KFA² GeForce GTX 560 EX OC 1GB
        AMD Radeon HD 6950 2GB
        AMD Radeon HD 6950 1GB
        AMD Radeon HD 6870 1GB
        AMD Radeon HD 6850 1GB
        Nvidia GeForce GTX 550 Ti 1GB
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
    Frames Per Second
Read our
Performance Analysis.
