Athlon X2 7750 vs. Intel E5200 OC & Value
December 22, 2008 | 08:26
Tags: #athlon #benchmark #cpu #kuma #overclock #overclocking #processor #review #testing #value #x2
Companies: #amd #test
PCMark Vantage x64
Publisher: Futuremark
PCMark Vantage x64 is a Vista-only 64-bit productivity benchmark that tests a range of standard application types providing a general performance number in respect to other systems.
It tests multi-core processors and requires a processor with at least SSE2 support and a graphics card that supports Shader Model 2.0 or higher.
There are test scenarios for High Definition TV and Movies, Gaming, Memory, Music, Communications, Internet, General Productivity and Hard Drive. They cover the broad range of typical software a PC user will use and acts as a good "one stop" benchmark for general system performance.
PCMark Vantage x64
Overall Score
  • Intel Pentium Dual Core E5200 OC (2x4GHz, 1333MHz FSB)
  • AMD Athlon X2 7750 OC (2x3.1GHz, 1.8GHz HTT)
  • Intel Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
  • AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
  • AMD Athlon X2 7550 (2x2.5GHz, 1.8GHz HTT)
  • AMD Phenom X3 8450 (3x2.1GHz, 1.8GHz HTT)
  • AMD Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
  • AMD Athlon X2 5200+ (2x2.7GHz, 1.0GHz HTT)
  • AMD Athlon X2 4850e (2x2.5GHz, 1.0GHz HTT)
  • 5244
  • 4314
  • 4135
  • 4127
  • 4000
  • 3973
  • 3871
  • 3723
  • 3538
2000
3000
4000
5000
PCMarks
Athlon X2 7750 vs. Intel E5200 OC & Value PCMark Vantage x64 and CineBench 10
Like we'd expect, the overclocked Intel E5200 performance is well ahead of everything else and drives itself very much closer to the good value area than the AMD CPUs, including the overclocked 7750 BE that doesn't yield that much more value, which all clump around mid table along with the stock clocked Intel E5200. The tri-core Phenom again sits in the negative value area with its mediocre performance and respectfully higher price.
Maxon Cinebench 10 x64
Website: Cinebench
Maxon Cinebench is based on Maxon's popular animation software, Cinema 4D, which is used extensively by studios and production houses worldwide for 3D content creation. We've used the built-in CPU benchmark, which uses a 3D scene file to render a photo-realistic image of a concept bike. The scene makes use of various CPU-intensive features such as reflection, ambient occlusion, area lights and procedural shaders.
Cinebench 10
x64 Version - xCPU, 800x600 Image
  • 8778
  • 6502
  • 6462
  • 5764
  • 5673
  • 5374
  • 5350
  • 4944
  • 4391
2000
3000
4000
5000
6000
7000
8000
9000
Score
Cinebench 10
x64 Version - 1CPU, 800x600 Image
  • 4641
  • 3422
  • 3009
  • 2950
  • 2792
  • 2726
  • 2404
  • 2394
  • 2267
2000
3000
4000
5000
Score
In the multi-threading Cinebench test again the overclocked Intel E5200 stretches a very healthy performance advantage and subsequently great value too, and even the 7750 OC stretches out a bit from the trend of stock clocked AMD and Intel CPUs down the middle. Also, in the single threaded test the 4GHz Intel CPU unsurprisingly dominates the field, affording a massive gap between itself and the overclocked Athlon X2 7750 BE which is only a nose faster in comparison to the rest of the CPUs below it.
