Power Consumption
The idle power consumption beats everything we've tested previously, and the DES Advanced seems to make a few additional Watts of difference - more than the older EP35-DS4 and it's a noticeable ~15W lower than the DS3R as well.
When loaded, the UD3R can't match the MSI P45 Platinum and it's a few Watts more power hungry than the DS3R and older EP35-DS4 here, but since the performance in general is that much better it's arguably very worthwhile.
Compared to other boards like the Maximus II Formula it is a single watt lower power, but it also features considerably less performance hardware - the same can be said for the Asus P5Q Deluxe too.
Power Consumption (Idle)
Power at wall socket. BIOS Defaults, all onboard hardware enabled. Windows Desktop Idle, Prime95 Tor
  • Gigabyte GA-EP45-UD3R (DES Advanced Enabled)
  • Gigabyte GA-EP35-DS4 (DES Enabled)
  • Gigabyte GA-EP35-DS4 (DES Disabled)
  • Asus Maximus II Formula (EPU Enabled: Auto)
  • Gigabyte GA-EP45-UD3R (DES Advanced Disabled)
  • Asus P5Q Deluxe (EPU Enabled: Auto)
  • Asus P5Q Deluxe (EPU Enabled: Auto, 1% CPU Clocking)
  • Asus Maximus II Formula (EPU Disabled)
  • MSI P45 Platinum (GreenPower Enabled)
  • MSI P35 Diamond
  • Gigabyte GA-EP45-DS3R (DES Advanced Enabled)
  • Gigabyte GA-EP45-DS3R (DES Advanced Disabled)
  • Gigabyte GA-X48T-DQ6 (DES Enabled)
  • Asus P5Q Deluxe (EPU Disabled)
  • Gigabyte GA-X48T-DQ6 (DES Disabled)
  • Abit IX38 QuadGT
  • Gigabyte GA-EP45-DQ6 (DES Advanced Enabled)
  • MSI P45 Platinum (GreenPower Disabled)
  • EVGA nForce 750i SLI
  • Gigabyte GA-EP45-DQ6 (DES Advanced Disabled)
  • XFX nForce 780i SLI
  • 106
  • 107
  • 110
  • 111
  • 111
  • 113
  • 114
  • 115
  • 118
  • 119
  • 119
  • 120
  • 121
  • 122
  • 123
  • 125
  • 130
  • 130
  • 135
  • 135
  • 150
50
75
100
125
150
Watts (lower is better)
Power Consumption (Load)
  • MSI P35 Diamond
  • Abit IX38 QuadGT
  • 155
  • 169
  • 170
  • 171
  • 173
  • 174
  • 174
  • 174
  • 175
  • 177
  • 178
  • 180
  • 183
  • 183
  • 184
  • 184
  • 185
  • 188
  • 191
  • 192
  • 196
100
150
200
