Intel's Core i7 920, 940 & 965 processors
November 3, 2008 | 08:30
Tags: #2 #920 #945 #965 #benchmark #comparison #core #cpu #i7 #mode #nehalem #penryn #performance #phenom #quad #result #review #smt #testing #turbo
Companies: #amd #intel
Power Consumption
When we test power consumption, we consider it as a whole platform so whether the CPU includes a memory controller or it's separate on the northbridge doesn't make a difference to what we measure at the wall and how much electricity is paid for. The Core i7s are built on a 45nm process which should be low power, and with all the Power Saving gizmos from the CPU, memory and QPI etc turned up to eleven we set about seeing whether this meaty platform could go to sleep and stay quiet.
While it's difficult to compare the motherboards in an apples to apples scenario, none of the motherboards used feature specific power regulation for the CPU phases and all of them are performance parts from DFI, Intel and Asus.
The results are extremely impressive for idle power consumption which are all lower than a dual core Wolfdale built on the same 45nm High-k Metal Gate process. Even though there are a large number of transistors in the 8MB L3 cache that are still active in the C6 sleep down state, the at the wall power consumption certainly says a lot about the new global power management built into Nehalem.
The key difference between Nehalem and Penryn is that Penryn is limited by die level C-state but Nehalem extends this into individual core C-states that allows far greater finesse in lowering the overall power. With Penryn, each die has two cores (the quads are made from two dies) and so if one of the two cores is woken to do something they both have to power up ready, even if the second core is not needed. Nehalem doesn't have this problem.
Even the load power consumption on the new Core i7 isn't too bad considering there's an extra memory module in use and the CPUs are all rated at a 130W TDP. Plus there's the fact that Hyper Threading means more of the CPU Pipeline is in use at any given point in time. QPI, while a low power link, is far faster than the old Front Side Bus model so that uses a lot of power too - we can see the significant jump between Core i7 940 and 965 in the graphs below, but that might also be attributed to the extra CPU voltage as well.
Idle Power Consumption
Power at wall socket. BIOS Defaults, all onboard hardware enabled. Windows Desktop Idle
  • Core i7 940 (4x2.93GHz, 45nm)
  • Core i7 920 (4x2.66GHz, 45nm)
  • Core i7 965 (4x3.2GHz, 45nm)
  • Core 2 Quad Q9450 (4x2.66GHz, 45nm C1, DDR2)
  • Core 2 Duo E8500 (2x3.16GHz, 45nm C0, DDR2)
  • Core 2 Quad Q9650 (4x3.0GHz, 45nm C0, DDR2)
  • Core 2 Extreme QX9770 (4x3.2GHz, 45nm C0, DDR2)
  • Core 2 Quad Q9550 (4x2.83GHz, 45nm C1, DDR2)
  • Core 2 Quad Q9650 (4x3.0GHz, 45nm C0, DDR3)
  • Core 2 Duo E8500 (2x3.16GHz, 45nm C0, DDR3)
  • Core 2 Quad Q9450 (4x2.66GHz, 45nm C1, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 45nm C1 DDR3)
  • Core 2 Extreme QX9770 (4x3.2GHz, 45nm C0, DDR3)
  • Core 2 Quad Q6700 (4x2.66GHz, 65nm G0, DDR2)
  • Core 2 Quad Q6700 (4x2.66GHz, 65nm G0, DDR3)
  • AMD Phenom X4 9750 (4x2.4GHz, 65nm B3)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 65nm B3)
  • AMD Phenom X4 9850 BE (4x2.5GHz, 65nm B3)
    • 103.0
    • 103.0
    • 104.0
    • 107.0
    • 107.0
    • 107.0
    • 107.0
    • 108.0
    • 113.0
    • 113.0
    • 113.0
    • 114.0
    • 115.0
    • 130.0
    • 133.0
    • 137.0
    • 137.0
    • 137.0
50
75
100
125
150
Watts (lower is better) - Average Reading
  • Idle
Load Power Consumption
Power at wall socket. BIOS Defaults, all onboard hardware enabled. Prime95 Load
  • Core 2 Quad Q9550 (4x2.83GHz, 45nm C1, DDR3)
    • 142.0
    • 152.0
    • 175.0
    • 177.0
    • 178.0
    • 179.0
    • 179.0
    • 180.0
    • 184.0
    • 186.0
    • 196.0
    • 211.0
    • 215.0
    • 240.0
    • 243.0
    • 247.0
    • 254.0
    • 256.0
100
150
200
250
  • Load
null
